HELP WITH SEALING PROBLEM
Discussion in 'Miscellaneous Repairs & Maintenance' started by AJDRAGON, Oct 1, 2021.
  1. AJDRAGON
    AJDRAGON New Member
    27
    Jul 23, 2021
    Puyallup Wa.
    Hi
    I'm trying to reseal the back lower corners of my sisters camper, but there a real mess, see pic's, the last person to work on this thing did a really bad job of repairing it. I can't get the original rails to go back on and seal properly. Would using 1.5" aluminum angle be a viable replacement option?
  2. PopUpSteve
    PopUpSteve Administrator
    20,010
    2,932
    Dec 22, 2002
    Malvern, PA
    Making replacement is your best option. I would do at least 3 inches on either side and if you can get to the corners from the inside, put some plates there to bolt into for added strength.
  3. xxxapache
    4,089
    2,372
    I would put some angle brackets on it to hold the corner together, then cover it with 4" Eternabond tape from top to bottom.
