Help
Discussion in 'First Time & New Camper Owners' started by xRampagex, Oct 1, 2019.
  1. xRampagex
    xRampagex Member
    31
    Sep 6, 2019
    Michigan
    Can someone tell me how to remove this corner trim? I need to replace some rotted wood in this corner.
    Thanks!!
  2. PopUpSteve
    PopUpSteve Administrator
    18,800
    1,568
    Dec 22, 2002
    Malvern, PA
    Need Make/Model/Year for someone to help.
    Arlyn Aronson likes this.
  3. Arlyn Aronson
    Arlyn Aronson Well-Known Member
    1,168
    609
    Jun 11, 2014
    Houghton, MI
    I'm no expert but if the center section of that trim is soft or rubber like, I'd guess you pull it off and you'll see screws under it.
    BillyMc likes this.
  4. xRampagex
    xRampagex Member
    31
    Sep 6, 2019
    Michigan
    94 Palomino Stallion
  5. xRampagex
    xRampagex Member
    31
    Sep 6, 2019
    Michigan
    Your an expert to me, your absolutely correct, thank you!!
  6. joet
    4,583
    872
    When removing it..pull it off even this will help from bending it. The screws most likely will require a square bit
    xRampagex likes this.
  7. BillyMc
    BillyMc Well-Known Member
    1,007
    447
    Mar 25, 2018
    If the trim insert tears or cracks don't fret, replacement is inexpensive.
  8. xRampagex
    xRampagex Member
    31
    Sep 6, 2019
    Michigan
    I did find and buy 100ft roll of this on Amazon for about $9. It was very brittle when removing the old stuff.
  9. Raycfe
    15,072
    1,359
    You are an expert to me also.. A package of wood shim will help with the removal. Use a bunch of them in a row to slowly remove the trim with the least amount of damage. May be held on with square drive screws, double check that you have all of them out first.
  10. xRampagex
    xRampagex Member
    31
    Sep 6, 2019
    Michigan
    IMG_20191004_150517062.jpg IMG_20191004_150501412.jpg IMG_20191004_125216817.jpg IMG_20191004_150527097.jpg IMG_20191004_125244699.jpg IMG_20191004_125239233.jpg IMG_20191004_102601389.jpg IMG_20191004_135835912.jpg IMG_20191004_165508260.jpg IMG_20191004_134817023.jpg
  11. xRampagex
    xRampagex Member
    31
    Sep 6, 2019
    Michigan
    IMG_20191002_184739923.jpg IMG_20191002_184804030.jpg IMG_20191002_184753464.jpg IMG_20191002_184819410.jpg
  12. xRampagex
    xRampagex Member
    31
    Sep 6, 2019
    Michigan
    I have every bit of rot out of this camper. Everything is sprayed for mold control.... Just in case and is currently drying out. Once everything is put back together and sealed properly, the interior is being completely renovated. Let the fun begin.
    FARfetched, Sjm9911 and Rik Peery like this.
  13. Dback2k4
    Dback2k4 Active Member
    413
    208
    Jul 16, 2017
    Iowa
    Looks like quite the project!
