Blingnurse24
I just got a 1998 StarCraft. I believe it has a Shelby 5438 lift system on it. When you crank it, it starts to go up then starts popping and won’t go. With help pushing the top it will occasionally grab and go up then start popping again. Looking underneath at it I think the teeth on the gears may be worn. Could that be it? Any way to suggest to fix it? I have read you can’t order parts for that lift anymore.
How expensive is it to have the whole lift system changed out?
Thanks
Thanks
