here's a doozie
Discussion in 'Lighting, Interior and Exterior' started by jacrabbitt, Aug 19, 2018.
  1. jacrabbitt
    jacrabbitt Active Member
    234
    51
    Mar 27, 2015
    Michigan
    So I start changinng out my light fixtures to LED tv is playing... flip the light switch
    No tv reception. Turn the LED off get tv reception.. Anybody have this prob? Tech said LED emitting frequency that interfears with tv reception. Same deal in my old hybrid too.
  2. Sjm9911
    9,337
    6,735
    Yes , I have a shop light that interferes with stuff in the house. I had to move it.
  3. Canadian Campers
    Canadian Campers New Member
    24
    May 22, 2018
    Caledonia, Ontario, Canada
    I recommend getting rid if the TV and your problems will be over.
    You're welcome
    rescamilla, 8lugnutz, jnc and 6 others like this.
  4. roybraddy
    roybraddy Well-Known Member
    2,394
    952
    Mar 23, 2016
    King George, Virginia
    Yup... Some of thos LED lights that have a built-in voltage regulator that will cause RFI interference with things like your HDTV, AM/FM Radio, WX RADIO, etc... Way back when the LEDs lights started getting popular I of course ordered a whole set of LED lights to replace all of mine at one time... That was a $150 dollar mistake haha...
    Then i learned to only buy one and see if it works good with everything else then go get a bunch of them...
    Even today I can pull up behind some of the tractor trailer trucks that has LED rear lights running and my Ham radio starts acting up... Back off fifty feet and it all clears up haha...
    There used to be alot of conversations on this so that most everyone would get the picture but I guess it has slowed down somewhat. Every now and then we hear of some with your same problem. Last one i heard was turning on the light in the bathroom after they installed a new one with fan and light combo. Made their TV go blank too haha...
    I guess you can start adding DC filters in the wiring everywhere but best thing is just get a different brand and try it out first. When I changed my lights out for LEDs they were all on a board so you see the voltage regulator chip on the board. I gave all of them away and got the cheap $4.99 a board from china and all been working great ever since...
    No chip
    I guess it is hard to tell when you buy the bulb replacement type... If the specs says they will work from 9VDC to 15VDC that will tell you they have a DC VOLTAGE REGULATOR CHIP in the unit??? The boards I got for my OFF-ROAD Trailer said they will work from 12.0VDC to 12.4VDC so I bought extra units and still have not had to change any out after several years of use...
    Roy Ken
    megcabra likes this.
  5. jacrabbitt
    234
    51
    Mar 27, 2015
    Michigan
    Thanks Roy, I was hoping the ol radio guy would have an answer. You the man.
