Hi from Edmonton, Alberta Canada, Recently purchased an older Starcraft Nova very clean inside and out and have been tinkering a bit checking things out. There is some water damage on the roof around the vent but from reading other posts i guess this is normal. One thing I am looking for help with is the hot water tank when i try to fill it the water just drains out. There are 2 grey tubes on the side 1 I am sure is to drain for high level and the other to drain. I can't seem to find a shutoff for the tube draining the tank???? Any help would be fantastic.
Welcome aboard. On our Starcraft, the valves for the water drains are on the bottom end of the hoses, under the floor... Right where they can get wiped off by a passing rock... This may have happened to yours...
Welcome from MI! I have a dear friend from Alberta. He's a musician, and his albums are always in our road trip rotation. His name is Scott Cook, you should check him out!
Welcome from Tucson AZ!!!! 2014 Flagstaff Mac 228d 2004 Ford Expedition 4x4 5.4L Sent from my iPhone using Tapatalk
