HI! Repair Question
Discussion in 'Introduce Yourself' started by spyderv3, Sep 23, 2019.
  1. spyderv3
    spyderv3 New Member
    Sep 23, 2019
    Hi Everyone!
    My family and I have been using our 2003 Coleman Sante Fe for a number of years, but after some roof damage we haven't been out in a while. I know the Coleman ABS roofs are known to have problems, but my I'm wondering if there is any real issue with cracks or if it is just cosmetic? It looks like there is fiberglass under the ABS coating, so I don't think any water can get through to the rest of camper. The roof is start to come off in big chunks, so I was think I would strip it entirely and coat with Grizzley Grip. Any thoughts or suggestions would be much appreciated!
  2. tombiasi
    5,817
    1,397
    However you do it the roof needs to be repaired. Why are you worried about cracks if big chunks are falling off?
    Raycfe likes this.
  3. spyderv3
    spyderv3 New Member
    Sep 23, 2019
    I don't think the fiberglass in damaged, so I'm hoping I don't need to repair that. I'm thinking a needs to scrape off the ABS coating and cover the entire roof with Grizzley Grip.
  4. tombiasi
    5,817
    1,397
    If you are sure that is fiberglass under, go for it.
  5. spyderv3
    spyderv3 New Member
    Sep 23, 2019
    That's a good question. I'm not sure it if fiberglass.
  6. GreyFox
    GreyFox Well-Known Member
    2,165
    1,095
    Oct 10, 2018
    S Ontario
    The interior of a Fleetwood ABS Strata roof was rigid foam, nothing else. This is a pic of my own 2000 Santa Fe after I cut in intake and output holes for a Carrier AirV A/C I installed on the camper.
    To the OP - any water that leaks into your roof will eventually destroy it.
  7. tombiasi
    5,817
    1,397
    It would not make sense to me to be fiberglass.
    Read GreyFox above.
  8. spyderv3
    spyderv3 New Member
    Sep 23, 2019
    Thanks. I guess I wont' know for sure how bad the damage is until I take the ABS coating off. The top layer is in tough shape. The rest of the camper is in good shape, hopefully it can be repaired.
  9. Sjm9911
    6,377
    3,734
    Strip it and re do with gg. Mine looks the same as yours, and i sware it had a fiberglass undercoating. Gray foxes didnt, but then again according to grey fox they had 2 diffrent manufactures for the abs roof. Maybe they tried to fix a prodution problem, or speed it up? I dont really know. I do know that the undercoating felt tough. And not like foam at all on mine.
  10. GreyFox
    2,165
    1,095
    Oct 10, 2018
    S Ontario
    Wow, that's an understatement! :eek: You might want to read through this discussion which describes how another ABS roof owner used Grizzy Grip to restore his roof to usable condition.
    https://www.popupportal.com/threads/coleman-fleetwood-roof-repaired.122287/
  11. Raycfe
    16,912
    2,489
    Never saw a roof so bad . Strip it. Seal what's underneath.
