bheff
There you go...run your hitch like the middle picture
Right. The shank can't be inserted into the receiver upside down but you can slide the bar out of the top and insert it from the bottom. Like the diagram posted by Jawritch and bheffI'm about 95% sure that those adjustable reese draw bars cannot be used upside down. The adjustable part that the ball is mounted to can be used as a lift or drop, but the piece that slides into your trailer hitch must be as shown with the longer end down.
Determine which has a greater height—your hitch or coupler—and find the difference between the two measurements:I just got a new tv... Ram1500. The top of the hitch ball on the truck is 24 inches from the ground. The top of the hitch on the camper is 21.5 inches from the ground. Will that 2.5 inch difference be ok? View attachment 60669 View attachment 60670
