Homemade wheel stops
Discussion in 'Stabilizing Your Camper' started by canoehenge, Oct 7, 2013.
  1. canoehenge
    canoehenge 1997 Jayco1206KB & 2006 Terry 28' 2012 Tundra
    57
    Mar 11, 2012
    4x4s cut at 60 degrees with narrow portion at 6 inches, 1/2 inch all-thread, some nuts and washers. Spent less than $15 for items costing at least $50. Works great to stop that end to end motion when moving around the trailer.
  2. canoehenge
    57
    Mar 11, 2012
    Picture of wheel stops.
  3. esgordon123
    esgordon123 New Member
    121
    May 23, 2011
    I will have 2 of these by the end of the week.
  4. Wizfisher
    Wizfisher New Member
    1,271
    Mar 5, 2009
    I made mine the same way and they make such a big difference.
  5. Snow
    10,573
    1,340
    Made a set of those the day after the TT followed us home... I have read that it is suggested using regular chocks first, then complete your leveling front to back, then install these chocks.. if you installed them first you will put excessive pressure/force on the suspension.. not sure how true this is, but whenever possible I do it.. Also after a few hours of the next day give them an additional turn or two as they will loosen up as the tires cool down after traveling...
  6. mschepac
    mschepac South Jersey
    1,386
    Apr 22, 2008
    South Jersey
    I used pipe clamps. This way I didn't have to deal with remembering a wrench. I got the pipe clamps from HF.
  7. SUPERKSR
    SUPERKSR Member
    277
    Jan 27, 2010
    NICE! Clever. I love repurposing a common item for another task.
    Questions: What are the "wedge" pieces made of?
    If hollow/pipe, are they reinforced to prevent crushing?
    Do they slide along the length of the bar clamp with a through hole, or are the only notched to slide around the pipe?
  8. mschepac
    1,386
    Apr 22, 2008
    South Jersey
    I actually used landscape timber that I had laying around. I painted them black so they didn't look so 'home made'. I bored a hole through the middle. The 'chocks' slide freely up and down the length. The pipe clamp end moves to make installation easy.
  9. CNC0129
    CNC0129 Member
    198
    Sep 6, 2013
    Good idea. Might make these for my parents TT.
  10. SUPERKSR
    SUPERKSR Member
    277
    Jan 27, 2010
    Well, very good!
    Can't use them on the pup, but someday (only a short 20-25 years out)I will have a fifth wheel...
  11. tenttrailer
    3,348
    415
    Jul 18, 2013
    Thornville, OH
    I seen them made like your's but with a turn buckle.
  12. blackbear
    blackbear We want to do this for a living !!!
    290
    Jul 19, 2012
    Great idea, thanks [RTM]
  13. esgordon123
    121
    May 23, 2011
    I made them for the travel trailer. Made a huge difference. Thanks for the idea. It also cost less than 10.00
