Hooked up my popup for the first time
Discussion in 'Tow Vehicles, Hitch & Towing' started by GreenEnvy22, Feb 26, 2016.
  1. GreenEnvy22
    GreenEnvy22 Member
    57
    Jan 17, 2016
    I finished the wiring for the trailer hitch yesterday, so hooked up the popup to our Escape today and did a test drive. Seemed to handle well. Definitely notice the extra weight accelerating onto the highway, but once upto speed it was fine. Also felt easy to pull at low speeds.
    Our first trip probably won't be until may or June, lots of work to do on the PUP.
    We bought this popup in January, found out it was 2000lbs empty, not 1500lbs, which necessitated buying a new (to us) vehicle for towing, hence the escape.
  2. 94-D2
    94-D2 Happy Campin'
    2,279
    134
    May 21, 2010
    Sutter Creek CA
    Isn't if funny how your pup dictates the other aspects of your life.......
    Congratulation on your new to you purchases. I can guarantee you have invested wisely. It is a nice looking couple.........
  3. Ny_Paul
    Ny_Paul New Member
    120
    Jan 31, 2016
    Very nice! I know you are not the only one who's pup dictated the purchase of a TV. Someone may have bought a Pup when they still owned a Honda Accord. Sometimes the cart does indeed come before the horse.
  4. Scottbaldwin01
    Scottbaldwin01 New Member
    48
    Jan 11, 2016
    Do you know what the tow rating is on your Escape? We have a 2008 Mariner (basically the same rig) and the only tow rating I found for it said 1500 lbs. Which is why we went with the Fleetwood Taos.
  5. Haybale
    2,487
    315
    Aug 22, 2013
    San Diego via MN
    Looks good!!
  6. speckhunter80
    4,782
    62
    Jul 26, 2012
    Shell Rock Landing, Hubert NC
    Pretty sure the 2007 Ford Escape is rated at 3500lbs with factory installed towing package
  7. bondebond
    bondebond New Member
    2,079
    Aug 14, 2008
    But if the OP had to do wiring to hook up the PUP, wouldn't that have been included in the factory tow package? Why would it have been left out if the tow package was already in place?
    GreenEnvy22, what wiring are you specifically talking about?
  8. Redbird
    Redbird Member
    135
    Feb 28, 2016
    West Michigan, USA
    Here's some towing information about Escapes. I had to research this myself when figuring out what my own vehicle would be able to tow.
    Whether towing is recommended with an Escape or not depends on what kind of Escape you have. The Ford Escape that is factory-equipped with a tow package (3.0L V6 engine) and is AWD has the highest GCWR. The maximum loaded trailer weight for the 3.0L V6 Escape with the tow package is 3,500 lbs. I don't believe the other versions of the Escape are recommended for towing, at least by Ford. There's a helpful chart that breaks it down on the link I posted above.
  9. Snow
    10,186
    1,089
    NEVER EVER use the dry weight of the trailer.. it is fictitious.. nobody ever camps with a dry trailer..
  10. Scottbaldwin01
    48
    Jan 11, 2016
    So it looks like the tow rating I found was for the four cylinder...could have gotten a bigger trailer I guess.[emoji20]
  11. speckhunter80
    4,782
    62
    Jul 26, 2012
    He may have had a factory installed wiring package for a 4 flat and he may have rewired to a 7 pin Bargman. My GMC Sierra had a factory tow package but it came with a 4 flat. Had to rewire for a 7 pin bargman.
  12. Nandy
    Nandy Active Member
    2,257
    Mar 29, 2010
    I do it quite a bit, 3 times a year to be exactl But when DW is camping with us guys then the world is a total different story!!!! lol!!!
    However, I agree, for most cases you need to add other weights.
  13. Snow
    10,186
    1,089
    You camp with nothing extra loaded inside the trailer and tow it with no awning, no propane tank(s), no battery, in many cases no spare tire, no water in the tank .. and remove all and any optional equipment ??? (This is a dry weighted trailer) ..
  14. GreenEnvy22
    GreenEnvy22 Member
    57
    Jan 17, 2016
    The 2009 + Escapes with the 3.0 V6 all have a factory transmission cooler. All the factory tow kit consisted of was a hitch and the wiring.
    I installed a flat 4 hookup, and have an adapter to goto a 7 pin, which is what the trailer has. No brakes on the trailer so I don't know why it has a 7 pin.
    The V6 will tow 3500 lbs.
    I want to do a transmission fluid change on our Escape since I have no idea if this is still factory fluid in it. When I do that I'll also add in a second cooler for the $40 it costs.
  15. Nandy
    Nandy Active Member
    2,257
    Mar 29, 2010
    for exception of the spare tire, yes sir. when we go fishing our trips are all included, all we bring is our butts so there is no cooking and other stuff. My coleman does not have any extra equipment. If it is a cold month then we take propane and a battery.
  16. Snow
    10,186
    1,089
    Then you sir are the only person I know who camps with a dry weight trailer ...
  17. Nandy
    Nandy Active Member
    2,257
    Mar 29, 2010
    Some of us treat them like glorified tents... 'Cept when the princes is aboard...
  18. Haybale
    2,487
    315
    Aug 22, 2013
    San Diego via MN
    No blankets, camping gear, nothing but original equipment in the up? Do you just pull everything out for the couple trips a year?
  19. bondebond
    2,079
    Aug 14, 2008
    Good grief. Enough with the nit picking.
  20. Haybale
    2,487
    315
    Aug 22, 2013
    San Diego via MN
    It is just hard to believe...
