Hooking up to electric at the campground
Discussion in 'Power - Site Power/Batteries/Generators/Solar' started by Toni Arnold, Jul 28, 2019.
  1. Sjm9911
    4,902
    2,585
    Ill agree , i here about them overhearing. Just never experienced it. If it dosent draw the volts , it shouldn't overheat. ( unless the manufacturing is bad) I cant see how it would overheat without what i said , excessive draw, or a bad conection. I just dont see it happening. Something else caused the heat up. Appliances will only draw what there capable of. Many people dont know this and will overdraw a circuit. Or it will arc because it was loose. Thats my personal, and professional opinion. I dont see a problem with the puck style, and use it and have had it hooked up for weeks in my own yard.
  2. Toedtoes
    Toedtoes Well-Known Member
    1,700
    1,357
    May 28, 2018
    If you are putting a light load on it, then it is probably going to be OK. But the dogbone will better handle a larger load. Also, if the puck overheats, it is more likely to damage your shore power plug due to the proximity.
    And for the difference in price, it makes more sense to buy the one that will handle a larger load. Especially if you will be using an AC, microwave, etc.overheats
    I'm not saying that everyone should throw out their puck if it is working for them. But if you are buying an adapter, the dogbone is the better choice.
  3. Sjm9911
    4,902
    2,585
    Ok , i give ! Lol. I think either is good. Just know the limitations.
    PointyCamper likes this.
  4. Vegas_PUPpers
    Vegas_PUPpers New Member
    22
    Jul 28, 2019
    Las Vegas, NV
    Chiming in to say I will be watching the heat levels on my puck, thanks for bringing it up! We have just done one boondock overnight so far, so I have not experimented with shore power configurations yet.
    Welcome to the forum @Toni Arnold, I'm new-ish too and have found these folks to be super helpful.
  5. Camper054
    Camper054 Active Member
    145
    61
    Jul 23, 2019
    Indiana
    Me newbie as well as I am getting ready for my first trip with the camper. If the 30amp socket at the campsite looks like it is 'damaged' and can potentially damage my camper plug, then maybe it is better to take my extension cord and plug it in the 120v and use my dogbone adapter to connect to the camper? Anyone sees anything wrong with this idea?
    Thanks!
    MC
  6. Sjm9911
    4,902
    2,585
    Mostly , you will only have 20 amp power, so no ac, of your running other stuff. Check the plug at the pole, most are good just a bit worn out.
  7. WrkrBee
    WrkrBee Well-Known Member
    2,674
    1,036
    Ask to move to another site.
  8. PointyCamper
    PointyCamper Active Member
    591
    159
    Nov 25, 2015
    Last year I was camping at French Creek SP and had a problem with the 30 plug. Maintenance actually came and replaced it . So let them know. Ymmv.
    Camper054 likes this.
  9. Toedtoes
    1,700
    1,357
    May 28, 2018
    Use your 30amp camper cord and use an adapter at the pedestal end to plug into the 20amp plug. This way you will have the higher rated cord for the greatest distance.
    As others indicated, this will limit your power. You may be able to run your AC, but won't be able to run other appliances at the same time.
  10. Camper054
    145
    61
    Jul 23, 2019
    Indiana
    Thanks for the comments and cautionary notes. I like the idea of having the campground folks 'fix' it. :). Just came back from our 'first' trip and the sockets looked good - so no workaround needed, at least this time.
    Thanks so much - happy camping you all-
    MC
