Hose connections!
Discussion in 'The Other Stuff' started by Sjm9911, Mar 30, 2019.
  1. Sjm9911
    4,672
    2,427
    Ok people, ideas needed here. Backround, in my old house i had nice old garden hoses that i connected to the hose bib every year, no problems. I moved 2 years ago and bought new hoses. I did get the heavy duty type, not cheap. When taking them in last year, they fused to the hose bibs. So im thinking dissimiller metals, aluminum and copper. I have 2 ideas, coat the conections with something. Teflon tape, valsiline etc, or cut the ends off and , go plastic. Im thinking the latter as my property is big and i need to change hoses and fittings a lot. Needless to say, i had quick connects, but they fused to the aluminum on the hoses also. What do you do? Why cant they just make copper ends! And im not buying new hoses, i have 6 between 75 and 150 feet. Not in the budget. Thanks.
  2. tombiasi
    5,364
    1,001
    You can get brass hose connectors.
    A little anti sieze may help.
  3. Sjm9911
    4,672
    2,427
    Lol, yes brass conections, not copper.
  4. Toedtoes
    Toedtoes Well-Known Member
    1,700
    1,353
    May 28, 2018
    Yeah, I'd put the brass ones on. They'll last longer than the plastic.
  5. Sjm9911
    4,672
    2,427
    So time to order a crap load of fittings, lol. Man i just wish they would leave crap alone and not change everything. I didnt even think about it untill i couldent get the hose off the front of the house. Oh well. Time to consult amazon.......
  6. daveo1289
    daveo1289 Active Member
    975
    81
    Apr 24, 2012
    Rochester NY
    Brass and/or copper will react with aluminum. Brass more so because of the zinc content. Add water and you'll get the galvanic reaction quicker. I've used a product called, "Never-seize" to prevent this.
  7. Sjm9911
    4,672
    2,427
    Dam new fangled hose ends, lol. Yes 8 might have to pick something along those lines up also.
