Hose to pup antifreeze through water pump
Discussion in 'Camper Storage / Winterizing & De-Winterizing' started by Spaceace5150, Oct 7, 2021.
  1. Spaceace5150
    Spaceace5150 Active Member
    202
    42
    Oct 1, 2014
    Unfortunately its the time of year to winterize my pup.
    I usually connect a hose to my inlet valve of the water pump and struggle to pump anti freeze through it that way. My hose is homemade and leaks and doesn't work that well.
    Does anyone have a solution that works well for them?
    I've seen these kits but don't know if they are the best solution:
    https://www.amazon.com/Camco-36543-Pump-Converter-Winterizing/dp/B0006JJ588
    Thanks!
  2. PopUpSteve
    PopUpSteve Administrator
    20,018
    2,949
    Dec 22, 2002
    Malvern, PA
    I empty my tanks and put antifreeze in them. Then I run the water until the antifreeze comes out the kitchen spigot (both hot and cold lines).
  3. xxxapache
    4,089
    2,375
    Make a better hose....You can get straight or 90 degree as needed at the hardware store.
    neighbormike and Spaceace5150 like this.
  4. Spaceace5150
    202
    42
    Oct 1, 2014
    Do you know what size of connecter you need to connect to the water pump?
  5. Sjm9911
    10,645
    8,034
    I put the antifreeze in the water tank when i had the pup ,and pumped it through that way. Like steve does. Easy but takes a little more flushing in the spring.
    Spaceace5150 likes this.
  6. xxxapache
    4,089
    2,375
    Mine is 1/2". I got a Sharkbite brand fitting and put it on s piece of clear hose using a hose clamp.
  7. Snow
    11,801
    2,380
    Try the hose from a hand held shower wand... that is what I use..
    xxxapache likes this.
