Hot water heater
Discussion in 'PopUpPortal TV' started by Nanapoppypops, Mar 25, 2020.
  1. Nanapoppypops
    Nanapoppypops Member
    218
    Mar 30, 2019
    I have a 2009 palomino "Y" series popup which we enjoyed after purchasing last spring. I never found a hot water heater in it after ripping everything apart to find it. Is that possible? Nothing surrounded by styrofoam. Am I overlooking something? Thanks
  2. Raycfe
    16,441
    2,231
    If you have a water heater you will have an exterior metal door about 12 x 12 to excess its controls. You will have a 2 handle faucet and usually an exterior shower also.
    neighbormike and kitphantom like this.
  3. Anthony Hitchings
    825
    371
    Mar 2, 2019
    We presume that you have a sink with hot and cold faucets. Correct?
  4. Nanapoppypops
    218
    Mar 30, 2019
    Thank you. I do have that door but where would the tank be or is there none? I did not bother with hot water last year so not sure. I have two faucets but no shower. Would I just ignite from outside where that panel door is? I taught myself a lot but did not get into this mostly because of fear! Thanks for the help
  5. Nanapoppypops
    218
    Mar 30, 2019
    Yes.
  6. Sjm9911
    5,886
    3,360
    The tank will be behind that door , usally 5 gallons. You light it on the outside after opening the door. You will need to acess the other side of the water heater to make sure its not bypassed and has water. Do not light it without water in it. That acess could be anywhere, under a seat, in a storage compartment etc.
  7. Raycfe
    16,441
    2,231
    Open the door and record the make and model numbers, should be on a tag along the side, or take a photo, and the portal can provide you will complete instructions.
  8. Nanapoppypops
    218
    Mar 30, 2019
    Okay. We live in Lake Placid, ny. Unfortunately I will not be able to uncover the pup for a bit et but will get back to you when that happens. Appreciate your help and I think I know where to look now. I'm hoping it's there. My goal is to use it this year(even if it's in my yard) and familiarize myself with that propane system and frig.
  9. Sjm9911
    5,886
    3,360
    Ok , i get the weather up there , lol. Our familly used to have a house in lake luzerne, in the lake george area. Post here when it warms up!
  10. Nanapoppypops
    218
    Mar 30, 2019
    Will do. I'm familiar with that area. Safety and good health to your family.
  11. bheff
    bheff Well-Known Member
    1,452
    846
    Feb 24, 2011
    NW Arkansas
  12. Nanapoppypops
    218
    Mar 30, 2019
    Very possibly I do not but there was something inlocatedcthatvyou could not get access to without removing some from f the bench. Two seniors camping with a new tons popup. Never iwnedconecfpbefore. Will take a pic of this in spring. Thanks
  13. Anthony Hitchings
    825
    371
    Mar 2, 2019
    Nanny, after uncovering the Pup at some future date, get your best wide-angle lens-camera combo and take a complete set of PUP photos, inside and out, including behind access panels and doors, for your use as a ready reference. Including the Manufacturer's Nameplate (with weight loading info). Also underneath (trying to catch gas lines and so forth), and axles, brakes and whatever. Its ever so handy to have this info available in the comfort of your house.
    Raycfe and Sjm9911 like this.
  14. Nanapoppypops
    218
    Mar 30, 2019
    Will do. Thank you
