Hot Water Issue
Discussion in 'Plumbing Systems (The Fresh, The Blue, The Grey, &' started by grsparty, Jul 11, 2019.
  1. grsparty
    grsparty New Member
    Mar 5, 2019
    Okay, so something real fishy is going on. I have zero pressure/water coming out of my hot water tap, but when I use the cold water faucet, there is hot water coming from the cold.
    What the heck could be going on?
  2. joet
    4,412
    810
    Valves on tank are set wrong. Tank is bypassed
    neighbormike likes this.
  3. grsparty
    grsparty New Member
    Mar 5, 2019
    Hot water tank is not bypassed.
  4. WrkrBee
    WrkrBee Well-Known Member
    2,103
    787
    If your supply hose is laying in the sun, you will get hot water out of the cold for just a little bit. Sounds like all three valves are closed at the water heater by-pass.
  5. WrkrBee
    2,103
    787
    If it's not by-passed, there's a kink or blockage. I'd probably start by pulling the hot water line on the faucet to see if you have a blockage there. The faucet probably has the smallest orifice in the hot water system. It would also tell you if you have hot water to the faucet.
  6. Dan Wilson
    Dan Wilson Active Member
    110
    81
    Jan 30, 2019
    Appleton, WI
    Make sure the faucets on the outside shower and inside shower are turned off, sounds like a cross connection.
    generok likes this.
  7. grsparty
    grsparty New Member
    Mar 5, 2019
    Okay, so I thought it might be the outside shower. I check that and I have both hot and cold coming from them.
    Next I’ll check for a blockage, but even if their is a kink or blockage, that doesn’t make sense that I have HOT water coming out of my cold tap.
  8. WrkrBee
    2,103
    787
    Are the water lines reversed on the faucet?
    theseus likes this.
