Hot Water Tank Removal
Discussion in 'Camper Restoration Projects' started by Richard Weed, Feb 4, 2017.
  1. Richard Weed
    Richard Weed New Member
    Jan 21, 2017
    Just started my remodel, 1993 Coleman Arcadia. Removed the cabinetry but I don't know how to remove the tank from the hot water heater? It's covered in insulation and cardboard now. Tried the search function here but keep getting an error message? Thank you in advance for your help.
    DW
  2. sea-piner
    sea-piner Member
    400
    Oct 9, 2015
    I am pretty sure that (if its the same as on my 1998 coleman sea pine) you'll have to remove the entire thing not just the tank, but others can chime in. you have to remove the door on the outside then there will be a flange with a bunch of screws. The heater then pulls out from the outside. You'll have to find some butyl tape when you put it back in. Your local rv dealer should have it.
  3. Richard Weed
    Jan 21, 2017
    Thanks, I did just what you said, slipped right out. Thanks again,
    DW
