How can i fine tune my side to side leveling?
Discussion in 'First Time & New Camper Owners' started by browntown3, Mar 23, 2011.
  1. browntown3
    browntown3 New Member
    19
    Jun 4, 2009
    Planning our first trip outside of the yard in our camper, My question is how can i fine tune the side to side leveling ? I found if i used a 2x4 on one side it was either a little too high or without it a little too low. Sorry for the silly question, just new to the whole camper experience :) thanks in advance!
  2. micbur
    micbur Working on "Camp Burton"...Opening Soon!
    974
    Jun 23, 2009
    Whitesburg, GA
    I have several 1x6 boards cut into different lengths...the 6" is wide enough to fit good under the tire and the 3/4" thickness give me the flexibility to use several. Being staggered the boards give me a gradual grade for backing up on them.
  3. NJGuy
    NJGuy Active Member
    2,353
    Apr 20, 2010
    I use different thickness of plywood boards to 'fine tune" the side to side leveling. I am sure others will recommend the BAL single wheel leveler.
  4. bud121156
    bud121156 Western North Carolina
    4,632
    37
    Apr 15, 2007
    North Carolina
    NJGuy is right....lots of folks use the BAL leveler.
  5. Hawkester
    Hawkester Hawkesnest
    1,337
    28
    May 23, 2008
    SE Wisconsin
    I would love to try the bal-leveler, (fathers day is coming)! but for now I use the lynks blocks. If adding/removing one is to much I use 3/4" piece of plywood.
    When i used wood it was the same with 2x4's or 2x6's. A 3/4" piece of plywood is half the thickness of the 2x4 or 2x6, so use that as needed to "fine tune".
    I painted all of my wood to seal it and keep it from rotting and it makes it look better.
  6. Travelhoveler
    Travelhoveler New Member
    2,337
    Mar 8, 2011
    Have a few boards of different thicknesses. After a number of trips, you'll be able to look at the wheels and determine quickly which one will get you level. Practice makes perfect.
  7. mschepac
    mschepac South Jersey
    1,386
    Apr 22, 2008
    South Jersey
    If you are looking for exact, BAL leveler, no question. Other than that, several thicknesses of boards.
    I have done it both ways but the BAL is by far the easiest and most exact way....
    ms
  8. GoDuke1
    GoDuke1 New Member
    65
    Feb 15, 2011
    I use the BAL Leveler, and it does double duty as a wheel chock too.
  9. rabird
    7,268
    540
    N. TX
  10. Retired Alex
    Retired Alex New Member
    1,120
    Oct 2, 2003
    Limoges, Ontario
    Build a ramp or cut a 2ft 4x4 along the diagonal to make a ramp.
  11. Flyfisherman
    Flyfisherman New Member
    3,682
    Mar 4, 2003
    Shallotte, North Carolina
    I've finessed it down to just two different boards ... a 1" X 6" and a 2" X 6", both maybe 12" long. Works every time.
    Whatever you do, don't yield to one of those woosie BAL levers. Just ask yourself, would one of those canvas covered rigs like what's posted below ever succumb to a BAL leveler(?)
  12. mckeapc67
    mckeapc67 New Member
    681
    Feb 22, 2011
    As another newbie, just how level do you really need to be?
    I would think that 1 3/4 inches (2x6 thickness) over the width of the PUP should be good enough. Certainly 3/4 inch (1x6) over the width.
    Is the fridge that picky? Or the roof raising? Or the entry door? Also what about if you are parked on a dirt, sand, or gravel pad; do you have to re-level when it settles or before you lower the roof? The PUP can't be that picky, can it?
    Also at the risk of starting something, when you put down the stabilizers, they can move the low side 1/2 inch or so. I know you shouldn't be lifting the PUP with the stabilizer, but on mine, it only takes a fraction of a turn on the handle to move the trailer 1/2 inch.
    Personally, I made a ramp that I back (or pull forward) onto. With a tandem axle, it gives me from zero to about 6 inches of rise over about 6 feet of length.
  13. Travelhoveler
    2,337
    Mar 8, 2011
    How picky do you need to be? Pretty close is good enough. Or do like we do and carry several boards of different thicknesses. After a while, you can look at the tire and see which board you need to make a precision fit.
    To be honest though, in about a third of the places we go, we can see a spot where we can pull the camper and it will be exactly level without any boards or leveling device. At other times, we disconnect and spin the camper to face a direction we prefer. With a variety of board scraps, only one or two of which you will use, you'll be fine.
    The board will prevent you from sinking in sand or gravel. Maybe not quicksand or mud, but we avoid those spots.
  14. micbur
    974
    Jun 23, 2009
    Whitesburg, GA
    I have been told the PUP needs to be fairly level for all things to work properly...if not the roof will lean to the low side and put added stress on the supports.
    Each site will need different levels of adjustment...we have about 4 1x6 boards we taken in the storage area. Most of the time we only use 2 boards at the most. Should never have to use boards ounder both wheels! [LOL] I have a 4' level I take that we keep in the storage compartment for this...also have an app on my smaprtphone for virtual level! [LOL] Just eyeing the level from side to side I can tell the low side and about how many boards to use. The thinner boards are the best cause if the 2x4 is to much what will you do if not on a dirt site?
    Just better for all the systems to be as level as possible. Never gone back to re adjust the level but have re tightened the stabalizers if needed.
    Never ever use the stabalizers to jack up the PUP. Can bend them and warp the frame of the PUP
    Just my [2C] worth
  15. Manper
    Manper New Member
    251
    Jul 7, 2010
    lynx levelers! there cheap and easy!!
  16. rabird
    7,268
    540
    N. TX
    Well that depends on your tolerance. Being off level has its benefits.
    The 'fridge line' is justification for some to be extreme IMO.
    Its their equipment though.
  17. cwolfman13
    cwolfman13 Active Member
    3,218
    Feb 9, 2011
    I use the "wussie" BAL Leveler....I can generally be perfectly leveled in a matter of a couple minutes and set up in 10-15....then I'm just drinking a beer and getting the fire ready. IMO, saves a lot of tiffs with the DW as well. I'm there to camp, not to spend a bunch of time backing up and down a bunch of boards until I'm level and arguing with the DW about which board(s) to use.
  18. micbur
    974
    Jun 23, 2009
    Whitesburg, GA
    cwolf...if you eye ball it right you only have to back up once. Only had problems using boards couple of times and that was right after getting the PUP 2 years ago. [LOL]
  19. JamesRL
    JamesRL New Member
    1,691
    Nov 1, 2007
    Brampton, Ontario
    Confession time.
    We don't have a leveller. Or boards, or blocks.
    We also don't have propane appliances.
    We usually find we can get close enough to level.
  20. ghacker
    ghacker Active Member
    3,438
    Nov 8, 2009
    I've tried both boards and a BAL. For me, BAL's the best. I like a bit of slope to help the A/C condensate to drain towards the side and a BAL allows you to put it right wear you want it. Also chocks it well so there's less movement when you're inside.
