How can I push my camper into the site and still level it?
Discussion in 'Leveling Your Camper' started by singerguy, Jan 27, 2021.
  1. singerguy
    singerguy New Member
    Aug 16, 2020
    Connecticut
    You guys are all the best. Thanks for your thoughts on this. I have camped several places in northern NH as a kid where we would back into the site and then align the PUP by hand for optimal site enjoyment. Now that I’m grown with my own I’m just trying to think the whole thing out. You’ve given me several good ideas to consider... much appreciated.
  2. Matt D Wilder
    Matt D Wilder Member
    48
    62
    Feb 27, 2019
    That gate will seem 10ft wide when you can clearly see everything so easily. I do not even need a spotter squeeking it into my garage.
    Susan Premo likes this.
  3. RonDad
    RonDad New Member
    18
    Aug 11, 2020
    Hey more pictures loaded in that post today than yesterday. You weren’t getting in that one with the TV.
    J Starsky likes this.
  4. Susan Premo
    Susan Premo Active Member
    386
    169
    Nov 5, 2020
    Minnesota
    Do you think it would work on grass, or gravel?
  5. Susan Premo
    386
    169
    Nov 5, 2020
    Minnesota
    I'll probably knock over said marker, trying to back In.
    Kyle R Thorson likes this.
  6. Eric Webber
    Eric Webber Well-Known Member Gold Supporting Member
    509
    396
    Jul 7, 2018
    Montreal, Quebec, Canada
    It does. To both.
    But you cannot go through anything too soft. For that, I keep two 8 inch wide boards to roll over when needdd. It will dig a trench through early spring wet soil
  7. Dingit
    Dingit Well-Known Member
    1,432
    893
    Mar 8, 2017
    I suspect it would work better with an Aliner than an Arcadia though, due to size and weight.
    Eric Webber and Susan Premo like this.
  8. Susan Premo
    386
    169
    Nov 5, 2020
    Minnesota
    Cool, that's what we have! Expensive I hear, but....we'll see if we end up needing it.
  9. Dingit
    1,432
    893
    Mar 8, 2017
    Well yeah, that's why I used it as an example. :p
    The smaller ones probably don't need a dolly at all to move about--you probably know by now if yours is one of them. The popup in my photo above was about 1900 lbs and we pushed that thing everywhere. It's one reason we suck at backing up our current trailer. No practice. It's easier to drop the trailer onto the ball than back the ball to the trailer!
  10. Susan Premo
    386
    169
    Nov 5, 2020
    Minnesota
    No, we haven't been able to use our aliner yet, we live in Minnesota, cold, and snow. But, I sure appreciate your help.
  11. unclemark
    unclemark Overland Park, KS
    396
    60
    May 15, 2014
    Overland Park, KS
    To the OP: I think this is reasonable. Be alert and cautious and keep your fingers away from the underside of the tire when the camper is jacked up, and even if the bottle jack tips over it's no big deal. You'll likely need to use this technique occasionally anyway, even if you manage to back into every campsite from now on. Maybe you'll misread your levels or the ground will be soft, or for some reason your camper door will bind up, and you'll need to straighten the camper after you've unhooked. A bottle jack is a wonderful thing.
