How do I fix this?
Discussion in 'Roof/Floor Repair & Maintenance' started by OKHappyCampers, Aug 14, 2019.
  1. OKHappyCampers
    OKHappyCampers New Member
    May 27, 2019
    Oklahoma
    IMG_6367.JPG I opened my 2015 FR Flagstaff 823D and the weather stripping that runs all the was around the inner lip is coming loose in a section.
    I cannot get it to reattach....any suggestions?
    What have you done in this case?
    Thanks in advance for your advice,
    Randy
  2. bobinfleet
    bobinfleet Active Member
    466
    190
    Sep 2, 2011
    Hampshire UK
    Hello and welcome from Hampshire UK[GBR] does it fit into a seal carrier? if not how about contact adhesive?
  3. Shaman1
    Shaman1 Well-Known Member
    2,237
    509
    May 13, 2011
    Oklahoma City, Oklahoma
    Welcome from OKC. You can use trim adhesive or diacor.
  4. joet
    4,825
    982
    Welcome from the mountains of West Virginia..3M weather strip adhesive
    myride, neighbormike and Raycfe like this.
  5. OKHappyCampers
    May 27, 2019
    Oklahoma
    Thanks, I like the idea of an adhesive and have some double sided gorilla tape to give it a try.
  6. bheff
    bheff Well-Known Member
    1,041
    527
    Feb 24, 2011
    NW Arkansas
    After you get it attached , use a rag and some dry silicone spray and wipe the bottom of the seal. Itll help to keep it from sticking to the lower part of the pup.
  7. OKHappyCampers
    May 27, 2019
    Oklahoma
    All fixed! Popped it back into the track and put a silicone rub on it
