How do you level your trailer?
Discussion in 'First Time & New Camper Owners' started by MyName, Jul 4, 2018.
Tags:
  1. MyName
    MyName Active Member
    290
    83
    Jan 12, 2018
    Ca
    I have 3 levels showing. Top left and bottom center are off. Top right is level.
    The bottom center was on the pop up trailer when I got it. What to do?
  2. kitphantom
    12,404
    1,392
    We did not use the roof to determine level on either pup, since it's too easy for that to be off a little. Our first pup roof was obviously a bit warped by the time we got it, which helped us know not to use it.
    We found a spot on the A-frame that agreed with longer levels, used on the floor inside,and used a small t-level. Once we determined that spot on the A-frame, we just use the small t-level. (BTW, we also learned to double-check the accuracy of the t-level with our other levels too. One of the new ones we had in the tool box this spring was definitely off.)
    On our second pup, the seemingly best place to put the t-level would have been on a flat cross piece- turned out that was not level compared to the floor inside. On the A-frame itself, it agreed with the inside.
    With our TT, we also used a small level in the 'fridge to make sure the floor and the level on the A-frame agreed with it.
    With a bit of practice, we learned to judge how many Lynx blocks to use under the low wheel, by how the bubble looks
    jumpoff and Rik Peery like this.
  3. xxxapache
    3,395
    1,382
    I have a big bubble on the front that I can see from the truck. I pull up on my Andersen levelers until its level side to side. I have another bubble on the side that I use for back to back....I mounted the aforementioned bubbles by using the inside of the freezer as a reference point.
  4. Raycfe
    17,006
    2,590
    Use the inside floor or a front mounted level on a panel. Just be sure the camper is level before attaching the level.
    The roof is the worse place to check for level. Level has to be checked on the fixed lower body.
    jumpoff likes this.
  5. friartuck
    friartuck Well-Known Member
    2,933
    136
    Nov 1, 2007
    Perry, MI
    I just use a 6" torpedo level on the tongue. Across on the brace and the A frame for side to side, and on one of the A frame members for front to back. It's close enough for us.
  6. nineoaks2004
    8,244
    3,694
    Dukes, Fl
    I have the bubble levels on my unit, but I usually use a small carpenters level especially front to back, I place it on the frame by the jack so I can see it.
  7. jnc
    3,931
    1,190
    Oct 1, 2014
    South Central New Hampshire
    To level side to side I use a 4' level across the tongue. For front to back I raise the roof enuff to use the rail the roof sits on.
  8. Snow
    11,028
    1,673
    We have two small stick on levels, one circular level on the tongue jack and I also carry a small torpedo level I can attach to the stove or fridge if needed..
  9. Toedtoes
    Toedtoes Well-Known Member
    2,516
    2,368
    May 28, 2018
    If you have a fridge, use a level inside it to first get your trailer level. Then, once it is level, find a preferred spot outside to put a permanent level - place that level so it reads level regardless of what that spot "thinks" is level. And do not use an independently movable spot like the roof.
    In your case, leveling on the roof can be warped if the roof is lowered or raised incorrectly or something inside is pushing on one side of the roof, etc.I
    the main purpose of leveling is to keep the fridge working. The trailer may not have been built so that the walls, floor, ceiling and fridge are all level against each other - so using the fridge ensures that it will be in the most level position when parked. If another part of the trailer is slightly off level from that, it isn't as big a deal.
  10. xvz12
    xvz12 Well-Known Member
    905
    555
    Apr 6, 2017
    ID
    Our pup doesn't have a fridge, so I generally just use a level app on my cell phone, & set it on the hitch or roof, seems to work OK for us. Down side of using the roof is I generally forget to take my phone off the roof, it ends up going up when I pop it up, then I spend a half hour looking for my phone....LOL. Yes, I suffer from CRS:confused:
    MyName and kcsa75 like this.
  11. kitphantom
    12,404
    1,392
    I had to laugh last year, on one of my solo trips. I had the TT leveled, using my old-school t-level and Lynx blocks. Just as I was finishing, one of the camp hosts came along and was going to help me by using the level app on his phone. Much to his (seeming) surprise, I had it correct.
  12. bols2Dawall
    bols2Dawall S.W. Ontario
    1,482
    169
    May 19, 2010
    Lasalle Ontario
    Don't use the roof to level
  13. justwork
    justwork Active Member
    153
    53
    Mar 27, 2017
    I just eyeball it.
  14. Fless
    Fless Active Member
    971
    211
    Aug 14, 2012
    Colorado
    This is the most accurate way. As @Toedtoes says, use the level inside the fridge if you have one, or level on the inside floor. Now that your camper is level, attach external levels to match the calibrated level side-to-side and front-to-back. Done.
    Or use your smartphone and a bubble level app on the floor, but that may take a lot of in-and-out movement to get it right. Some people use the levels that have audible tones when it gets to the point of level.
    _
  15. MyName
    290
    83
    Jan 12, 2018
    Ca
    Thank you everyone. I will use my new T level in my fridge to to verify my trailer is level and then find a good spot outside. I will also remove my semi-permanent roof top levels.
