Econ
If boondocking what method do you use? Always looking for better methods
This is a neat and different idea. You set it on a burner and the burner heats the water. I always thought this had its own fuel source, but kinda like the burner idea.Coleman stovetop drip coffee maker. https://amzn.to/2rqyNOt I upgraded mine with the Quickpot stainless steel carafe that seems to no longer be available.
I agree, drip is the best method. I once watched a documentary on coffee and they said the percolator bastardized good coffee...lol.They make a model that runs on propane called the Coleman Quickpot, this one just sits on the burner. I bought mine way before they came out with the quickpot. Percolated coffee can be quite bitter, so I wanted a drip coffee brewer instead.
Cheaper / simpler drip brewers are out there, they almost all are just cone filters that go over your mug. I have one for backpacking called the GSI Ultralight Java Drip, just heat your water in a separate pan, and run it through the filter / coffee into your mug. It's good if you are the only one drinking coffee...
French Press works well too, but not really my thing.
I use something called a myjoe I got from Amazon or a regular pour over. The coffee comes out kind of weak, but way better than what my outcome on the percolator made. Then again I never had much luck with my percolator. A friend made cowboy coffee but I just couldn't get myself to drink it.
