How hot?
Discussion in 'General Camping Discussion Forum' started by Weaversm, Oct 27, 2020.
  1. Weaversm
    Weaversm New Member
    Jan 22, 2016
    Hello. I have a 1994 Jayco 1207. I have run the heater very little at home but never camping. The heater appears to function fine, it cycles on and off correctly. My question is how hot the air coming out of the furnace should be. I checked it once and it was in the 150 degree range and I thought that was too high.
  2. gladecreekwy
    1,266
    1,840
    Sep 25, 2016
    Jackson Wyoming
    On mine the grate gets hot enough so you can’t keep your hand on it for more than a few seconds. Probably around the same as yours. Definitely can’t let stuff lay in front of it
  3. Andy G.
    Andy G. Member
    87
    68
    Sep 2, 2017
    WI
    Thats a pretty normal temperature. As mentioned, keep the area clear.
  4. Anthony Hitchings
    2,175
    1,190
    Mar 2, 2019
    Oakland, California
    Pretty darned hot - so if you hold cold clothes in front of it they heat up fast :)
  5. Weaversm
    Weaversm New Member
    Jan 22, 2016
    It just seems so hot. Especially only 20 inches from the dinette. I will probably experiment with it in the driveway this coming weekend. Thanks for replying.
  6. neighbormike
    3,127
    3,276
    Oct 6, 2012
    WI
    It should be hot - it’s a furnace. Typical duct temp in a car is around 140 with heat on high.
    gladecreekwy likes this.
