How much Airflow does a Solar Controller require?
Discussion in 'Power - Site Power/Batteries/Generators/Solar' started by mpking, Aug 20, 2019.
  1. mpking
    mpking Well-Known Member
    1,293
    312
    Jun 17, 2014
    Raynham, MA
    I'm toying with the idea of permanently mounting my solar controller.
    Right now I just sit it on the battery box, and connect my suitcase style panel to it. I've been toying with the idea of permanently mounting the controller inside the camper, and mounting a panel on the roof. (The style of camping we've been doing has us on the beach, so having a suitcase has not added value to us. I've typically just laid it flat on my roof the last 6 or 7 trips)
    My first thought is in a cabinet that we don't really use. My second thought was pull the false bottom out of that cabinet, and mount it under there. (I have a bluetooth adapter on the controller, so I haven't looked at the panel since I got it)
    The Cabinet is 12"x24"x36". The false floor is 10"x10"x36"
    Controller is Renogy Rover 20Amp.
    How much airflow is required for these things?
    Random thought as I type this. I could possibly fit it inside the backside of the fridge cutout. That has airflow. It'd be *REALLY* tight, and longer cables, and I've also toyed with the idea of removing the fridge and making that an inside/outside storage compartment, so I'd rather NOT do this. (it'd be in the way then)
  2. rabird
    6,745
    322
    TX
    I don't believe PWM controllers need much, your MPPT controller does produce some heat when it transforms panel voltage to battery voltage. The higher the input voltage the more heat would be produced. Using one '12v' panel or paralleling multiple '12v' won't produce much heat. That's my no specific random thought!
  3. gladecreekwy
    747
    850
    Sep 25, 2016
    Jackson Hole
    I’ve seen those controllers in very tight spaces
  4. SteveP
    SteveP Well-Known Member
    1,537
    424
    Inside a cabinet would work. I would mount it vertically for better airflow. My PWM manuals say to allow 1" clearance above and below for proper airflow.
  5. McFlyfi
    McFlyfi Active Member
    438
    184
    Aug 1, 2014
    Thousand Oaks CA
    I've got mine mounted in the front storage compartment, up high in the corner. If you can leave a little space around it, you'll be fine.
  6. BikeNFish
    BikeNFish Well-Known Member
    3,021
    1,922
    Apr 24, 2017
    Maplewood, MN
    I am no expert by any stretch of the imagination, but I have seen a couple of installation videos and they recommend six inches all the way around. If you look at THIS "Slim Potatohead" video, starting a 10:08, he mentions the controller placement, but he did not follow it due to lack of room in his Aliner.
  7. xvz12
    xvz12 Well-Known Member
    831
    473
    Apr 6, 2017
    New Plymouth, ID
    The PWM controller in my setup is located inside the battery box lid.....I've read it's not the best location for one, but it's finishing up it's second year with no problems.....yet *fingers crossed*[;)]
