how much tire?
Discussion in 'Taking Your Camper Off Road' started by albert, Jul 11, 2010.
  1. albert
    albert New Member
    Jul 11, 2010
    Just got a '82 starcraft. If I do a spring over swap how much tire can I get under it? Would love to see it on some 30"-31" inchers!!
  2. Yellowkayak
    2,198
    Mar 13, 2007
    The problem is the WIDTH not the height. Check how wide your wheel well is. I did the axel flip and gained six inches of heigth, but not width so I still can't put larger tires than my 14 inchers.
    JJ
  3. Atoyot1031
    Atoyot1031 New Member
    131
    Mar 15, 2008
    If you go with an axle flip as well as a block lift you should be able to run something decent. I clear 33s without wheel wells. Of course at that point, you have to address the stabilizer jacks as well as the leveling jack.
