how much wind???
Discussion in 'General Camping Discussion Forum' started by Beth, Sep 5, 2011.
  1. Beth
    Beth Member
    277
    Aug 17, 2009
    Spent the weekend at a local campground with friends...it was a great time...although "camping weather" didn't arrive until last night....that's ok though....anyway, we pulled home and unhooked and I popped the camper back up to finish cleaning, repack, and purge things we probably don't need to take.
    My question is, it's pretty windy here in camp backyard this evening....how much wind is "too much" to leave popped up in?? I was hoping to keep it popped up a couple days, but don't want to look outside and see a damaged camper in the yard....
    Thanks
    Beth
  2. Unstable_Tripod
    14,279
    29
    May 20, 2008
    Seattle, Washington
    Mine has survived 65-75 mph.
  3. Kutseena
    Kutseena Running with the wolves
    482
    Nov 14, 2010
    [:)C] We live in New Mexico and our winds are horrible in the spring. This June we had gust to 70 mph and they snap my shepards pole. I had to replace it.
  4. kreich
    kreich Member
    718
    May 5, 2007
    Hale Center TX
    In my tent pup we went through 60-65mph. In my A Frame so far we have been in 60 plus but have wind kit and that helped.
  5. radscj7
    radscj7 New Member
    May 11, 2008
    Mine has stayed intact and upright in 70 mph winds.
  6. bruceac1
    bruceac1 Member
    57
    Mar 19, 2011
    El Paso, TX 79924
    Mine had no problems in the 65 mph winds, but when it was hit with a 80-85 mph gust, the front bunk caused a lift. The result was the tongue end of pup being lifted about a foot, and the whole thing shifted three feet to the right, and it dropped about 18" into the dirt. No one was inside the pup when it happened, it was just setup in the backyard, and no one was outside, we just heard the wind when it rattled the rest of the house. We immediately took it down, but noticed after setting it up on the concrete slab that the curbside wall leans outward above the hinge (Palomino hardside pup) enough that the door binds when it is open. It seems that there is now a 5* list to the upper section of the wall. Not quite sure how to fix it, yet.
  7. robctry69
    robctry69 New Member
    155
    Jul 24, 2011
    5* do mean 5" if so thats a preety good amount can you set it up and push it back into shape
  8. bigdad
    bigdad Active Member
    3,577
    Mar 5, 2007
    Springfield Kentucky
    For the one who have a aframe camper what is a wind kit ??
  9. RonB
    RonB New Member
    454
    Jun 8, 2011
    We had a 70's vintage Starcraft PUP that withstood 60+ mph gusts twice several years ago. Not fun but it came through like a champ.
    RonB
  10. CarNutCass
    CarNutCass Put a little gravel in your travel
    805
    Mar 20, 2009
    St. Charles
    We camped on the Eastern side of the front range of the Rockies last summer and our pup survived sustained 30 mph winds with gusts to 40 mph. No damage at all. We left the canopy stowed to prevent damage.
