How often do you grease your balls?
Discussion in 'Tow Vehicles, Hitch & Towing' started by bsandey, Jul 17, 2017.
  1. kitphantom
    12,762
    1,799
    On our second popup, we had a hitch ball that was polymer, no grease required. It took a bit of adjustment when we went to the TT and had not only the hitch ball, but two smaller ones for the sway bar.
    If the sway bar ones aren't lubed they groan, a lot. On my long sessions of being hitched up (NM to OH and reverse), they will groan on the last day or so, more so if I've been driving in the rain.
    The main hitch ball shows wear from not having a heavy coat of grease, probably also those same long trips, when I stay hitched.
  2. inthedirt
    inthedirt Active Member
    977
    243
    Aug 28, 2012
    SW Montana
    Never.
  3. Dback2k4
    Dback2k4 Active Member
    446
    247
    Jul 16, 2017
    Davenport, Iowa
    Never. I have a triple-ball (which isn't as unique as you'd think ;)) that I rotate for the different trailers. My pup doesn't have a WDH or sway bars which would probably require more rigorous maintenance.
  4. Arlyn Aronson
    Arlyn Aronson Well-Known Member
    1,808
    1,368
    Jun 11, 2014
    Houghton, MI
    Replacement hitch balls are cheap and easy to replace. Some have gotten rusty so we have considered a stainless one. We're about to receive a new Tacoma so maybe get a SS one for it?? Accessories, accessories, accessories....
  5. soft 17
    soft 17 Active Member
    253
    111
    Mar 14, 2017
    San Luis Obispo
    Never on any hitch at work or at home. Now if I pulled a trailer every day I might.
  6. f5moab
    1,421
    471
    May 7, 2013
    Somewhere in Idaho
    Slightly!
  7. arthuruscg
    arthuruscg Active Member
    1,363
    Nov 14, 2012
  8. jerbear
    jerbear Active Member
    261
    61
    Jun 11, 2015
    Indiana
  9. SteveAZ
    SteveAZ New Member
    Dec 8, 2017
    Tempe Arizona
    As a newbie, I hadn't even thought about it. Our first tow (of anything) was our new camper - 1800 miles. There is obvious wear on the chrome of both the hitch and anti-sway bar balls. I put of thin coat of white lithium on them, and we'll see how the next long trip goes this spring.
  10. JimmyM
    JimmyM Well-Known Member Gold Supporting Member
    3,065
    1,047
    Jun 5, 2014
    Franklin, MA
    I use extreme pressure bearing grease on the ball and in the cup. But I use anti-seize on the WD bar pivots.
  11. Hoser
    Hoser New Member
    28
    Mar 11, 2015
    Once a year, whether it needs it or not...
    JimmyM likes this.
  12. jumpoff
    jumpoff I'm in a camping state of mind
    1,553
    190
    Nov 3, 2015
    North East Florida
    My question is...do you absolutely hafta grease your balls ?
  13. tenttrailer
    3,639
    581
    Jul 18, 2013
    Thornville, OH
    It will work just fine without grease, but will wear faster and might squeak.
    I grease ball and cup and about every 4-5 hitching, I wipe it out to clean it out from road dirt and re-grease it. I use wheel bearing grease that I carry in the camper.
  14. xxxapache
    3,649
    1,745
    No
