someguyinnorthcarolina
Active Scouter, new to the Popup World
I have been off the portal for about 7 years due to family caregiver issues, during which time my 2001 Coleman Bayside sat neglected in the back yard. We had bought it around 2012 and then "life happened" and we never even got to use it.
This week, with the help of a friend we opened it up. Surprisingly, after some cleanup, it's in good usable shape. My #1 first problem to fix is that the lights don't work. I honestly don't remember if they ever did. I do know the only thing I did when I bought the trailer was to put a new 7 pin wiring plug and harness on, and hook it up via a junction box to the trailer's wiring harness. But I don't remember if it ever worked when I did this.
I've verified all 7 pins are working right coming out of the TV.
I've verified that all 7 pins coming into the terminal junction box on via the new plug are good.
But on the wiring going into the trailer from there, I've got a problem. I don't have a color-coded list for the 2001 Coleman Bayside, but I'm pretty sure the colors are this (someone please correct me if I'm wrong):
White - ground
Black - 12V accessory hot
Red - left
Brown - right
Green - running
Blue - brake
Yellow - reverse
I have checked where the white wire grounds to the frame, and that still looks solid.
I have inspected the back of the trailer where the wires come through the subfloor to the rear panel, and see no cracks, etc
But using my ohmmeter, I have continuity between the green, brown, red, blue, and white wires. That should not be.
I guess in the worst-case scenario I can just start running new wires.
And I'd really like to avoid having to pull off the rear panel at this time just to get the lights working.
I'm hoping to get the trailer lights working first and then make sure the brakes work before making a decision about how much to invest (sweat and time and money) in some of the other repairs (cleaning up and grizzly-gripping the ABS panels and roof, replacing the seals, and replacing some rotted subfloor).
Thanks,
Carl
White - ground
Red - left
Brown - right
Green - running
Blue - brake
Yellow - reverse
Thanks,
Carl
