How to find parts
Discussion in 'Introduce Yourself' started by Vincent Ramirez, Mar 19, 2019.
  1. Vincent Ramirez
    Vincent Ramirez New Member
    Mar 19, 2019
    Flagstaff, AZ
    I just got a 1999 jayco eagle 10UD pop up trailer and it is in need of some TLC. It has some pieces that are warn out and broken and was curious if there is any company still selling parts for these trailers? I looked all over Google for the parts I need and to no luck haven't found anything.
  2. nineoaks2004
    7,306
    3,039
    Dukes, Fl
    Welcome from N/W Fl panhandle, congrats on the NTU PUP. Hopefully someone can assist you on your parts search. Good Luck and happy Camping
  3. joet
    4,699
    926
    Welcome from the mountains of West Virginia... Some of the parts are common parts that other MFG's use also.. It would help to know what you are looking for
  4. jmkay1
    4,835
    1,706
    Jayco is still around also so you can try finding a Jayco dealer. However I would probably first try elsewhere. Canvas replacement, eBay, Amazon all have had RV parts if you know the right keyword to use. Think that is the hardest thing is knowing the keyword. Some parts you can go to a regular hardware store and improvise. You can try listing what you are looking for perhaps someone here can give you a starting point.
    kitphantom and Raycfe like this.
  5. WrkrBee
    WrkrBee Well-Known Member
    2,485
    951
    Welcome to the Portal from South Carolina.
  6. JPBar
    JPBar Well-Known Member
    1,870
    575
    Sep 22, 2016
    Texas
  7. Shaman1
    Shaman1 Well-Known Member
    2,237
    507
    May 13, 2011
    Oklahoma City, Oklahoma
    Welcome from Oklahoma. What are you trying to find?
  8. BikeNFish
    BikeNFish Well-Known Member
    2,903
    1,806
    Apr 24, 2017
    Maplewood, MN
  9. Muller 5
    Muller 5 Active Member
    327
    153
    Jan 6, 2019
    STL
    Hello from St Louis
  10. Raycfe
    15,235
    1,449
    Greetings from the Connecticut shoreline.
  11. GreyFox
    GreyFox Well-Known Member
    1,403
    654
    Oct 10, 2018
    S Ontario
    A local Jayco dealer would be your most obvious source for parts specific to your camper.
  12. kcsa75
    kcsa75 Well-Known Member
    2,946
    1,348
    Sep 9, 2013
    Kansas City
    Congratulations on the NTU Pup and Welcome to the forum from Midway USA.
    You might check with Trailside RV in Grain Valley, Mo. They used to have a very detailed parts catalog online. I don't see it now, but they are a Jayco dealer, have a strong service department and are just good folks.
    https://www.trailsiderv.net/page/rv-parts-accessories-kansas-city
  13. tdiller
    tdiller Active Member
    255
    94
    Aug 25, 2016
    Depending on the parts etrailer.com
    Chris Short likes this.
  14. Vincent Ramirez
    Mar 19, 2019
    Flagstaff, AZ
    thanks for all the replies! still trying to learn the website and receive notifications through my phone but a couple things i am looking for are a new inside faucet my current one is a hand pump but the handle was broken when i got the trailer, thinking of possibly doing a faucet with an electric pump. also the door hinges on the small swing out door is pretty warn out as the hole door kind of moves up and down along with the swing down aluminum frame door. Also the door button sticks quite often along with the style of handle makes opening and closing a little difficult so ive been trying to look for new door handles as well with locks and keys as i dont have the keys for my current door handle. The aluminum frame door on my trailer also has these plastic pieces that are attached beneath the aluminum frame that slide into a channel on the trailer itself to keep the frame from being pulled apart by the canvas when popped up. Im currently trying to do a design to see if i can 3D print one but not sure on the strength of it. Ill post some pictures of my issues in a bit when i get home.
  15. Fishman1
    Fishman1 Member
    76
    33
    Jan 20, 2019
    Welcome from central Georgia.
  16. Vincent Ramirez
    Mar 19, 2019
    Flagstaff, AZ
    Really appreciate the responses and thanks JPBar for the link that website was just what I was looking for!
