How to Find Replacement Fitting for Jayco 1006 Supply Line
admittedlydutch
New Member
Aug 16, 2022
Last summer we bought a 2006 Jayco model 1006 pop-up, and the water system had never been used. Upon trying to use it for the first time we found this leak at the hot water supply:
I can’t tell which part is causing the leak, but either way: how would I go about finding replacement parts? I did a little bit of searching, but honestly I'm not sure where to start. Thanks!
Michael J
178
Michigan
I had to fix my fresh water on my camper I bought this spring due to the previous owner not winterizing it everything I had to replace was just PEX fittings the local hardware store had in stock, but I had to buy the special tool for the crimps I had to make in some areas I would start there.
