How to patch canvas bunk end?
Discussion in 'Canvas / Awnings / Add a Rooms / Tarps / Tents' started by DansAndDogs, Apr 19, 2010.
  1. DansAndDogs
    DansAndDogs New Member
    33
    May 20, 2008
    Southwest Virginia
    What is the best patch for a gaping whole with rought edges in my bunk end? The canvas has vinyl over it on the bunk ends, so whatever I use will be adhering to the vinyl.
    Thanks.
  2. 01YZF6
    01YZF6 Dothan, AL
    2,336
    Apr 5, 2008
    Mt. Washington, NH
    got a photo of the area perhaps? it may help in deciding the best way to go about this...
    however if it is going to be on the vinyl only, fo to any marine/rv dealer and get a marine vinyl patch kit....
  3. Dusty82
    Dusty82 Active Member
    3,513
    Jun 23, 2008
    Northern Nevada
    I'd agree with the marine vinyl patch kit. The patch would be applied to the outside and glued following the instructions in the kit. Don't try to oversew the vinyl patch - you'll just be putting holes in your roof.
    If you want to stitch a patch over the rip from the inside, then glue the vinyl patch to the outside after that, that would also work. It'll probably give you a bit more strength. Just be careful not to put your stitches too close together. Keep them so that you have about 4-5 stitches per inch. Any more stitches than that per inch and you're just perforating the vinyl, and it'll rip.
