How to put away awning...
Discussion in 'Canvas / Awnings / Add a Rooms / Tarps / Tents' started by KamperKel, Jun 17, 2018.
  1. KamperKel
    KamperKel Active Member
    149
    77
    Nov 5, 2017
    What is the best way to put away the awning to avoid damage from bad weather? My first thoughts were to lower the roof so we could roll up the awning and put it into the bag, but do I have to push the bed ends and side ends in before lowering?
  2. Raycfe
    15,432
    1,583
    I guess it doesn't matter. You just need to lower the roof enough to reach the awning bag.
    KamperKel likes this.
  3. Mamie
    Mamie Active Member
    839
    111
    Sep 11, 2017
    LA - Lower Alabama
    Just remove the shepherd's hook and leave the beds out.
  4. KamperKel
    149
    77
    Nov 5, 2017
    Thank you!
  5. JPBar
    JPBar Well-Known Member
    1,870
    576
    Sep 22, 2016
    Texas
    Here is my 2 cents. If you have to lower the top at least on mine you will have to remove the 4 vinyl flap covers from each post remove the 2 safety supports, the Shepard poles, lower each bed bow on each end, then I can lower the roof. This is what I did the one time I had to roll awning up after we have been set up, my awning (Trim Line) has 3 ties one on each end and one in the middle. I rolled it up and tied it off using the middle tie only. After weather moved on just unrolled it and set it back up. Fortunately my step is right where the middle tie is, took just a few minutes and did not have to tear down the camper.
    This is something you should try at home so you will know how difficult it will be at the camp ground. I would also suggest New PUP owners that you practice changing a flat tire at your house so you will know how to change one on the road when it happens and make sure you have all the correct tools to change it.
    Better to have and not need than need and not have!
  6. MrsSquid
    MrsSquid Active Member
    318
    114
    Aug 31, 2016
    Virginia
    Taking care of the awning without having to be concerned whether the roof is up is one of those places where my 6' 6" husband really comes in handy. ;)
    On the other hand, that lift crank on the back bumper, causes some pain.:eek:
    KamperKel, kcsa75 and JPBar like this.
  7. KamperKel
    149
    77
    Nov 5, 2017
    We will have to do the same procedure and add taking down shower area & side end poles. Great idea about practicing at home!!!
  8. JPBar
    1,870
    576
    Sep 22, 2016
    Texas
    Just noticed you had a HW with slide out dinning area and shower walls, That would be a little more work to get the roof down low enough to put the awning up. I see a step stool being added to your list of "I need one of these for the camper".
  9. KamperKel
    149
    77
    Nov 5, 2017
    Yeah, we thought of that and purchased one. But the hubby says he doesn't mind the extra work...I guess we shall see :grin:
    JPBar likes this.
  10. tfischer
    tfischer Well-Known Member
    3,551
    1,057
    May 21, 2014
    I'm tall so I can roll it up by standing on the step, tying 2 of the hold-downs (doing the rest when we break camp). If you're not tall enough I'd suggest bringing along a bucket, or milk crate, or step stool, or something else you can stand on, vs actually lowering the roof.
    KamperKel and JPBar like this.
  11. mstrbill
    mstrbill Active Member
    692
    145
    Mar 17, 2013
    Austin , Texas
    at least a 3 step one. Mine rides on the front bed next to the door, that I only have to raise the roof a few inches to grab it.
  12. KamperKel
    149
    77
    Nov 5, 2017
    Thank you everyone! We will try using our step ladder. It will save a lot of time if it works, lol
  13. Katskamper
    Katskamper Active Member
    750
    203
    Nov 21, 2015
    Fort Worth, TX
    AFTER the beds are pushed in, roof lowered, is when i fold up legs & roll it up. but im usually doing this alone
  14. KamperKel
    149
    77
    Nov 5, 2017
    Yeah, we do this when we are breaking down, but my concern was how to put away the awning for bad weather while the camper is popped up. Our popup has a lot of height due to the high walls. Hubby and I will have to see if our step ladder will work or just lower the roof enough to roll up the awning.
  15. tfischer
    3,551
    1,057
    May 21, 2014
    I've never actually put ours away for bad weather. Once or twice I added guy ropes to hold it down due to the threat of winds, but never actually pulled it. During a normal, non-severe rain, that's one of the best times to have an awning out... keeps the area in front of the pup dry.
  16. DJS12354
    DJS12354 Well-Known Member
    1,567
    492
    Sep 21, 2017
    Three step folding stool is a must with my bad knees. Can't just bounce onto or leap off the truck the way I used to. :(
