Bowman3d
Good job. Original pic showed 2 red wires.
I know! But I’m stuck at a campground trying to get home. I just need to lift my tongue jack and make sure my trailer brakes and emergency brake work. When I get home I’ll get a multimeter and check them.It can be very confusing, as older campers (my ‘94) used “white = negative, black = positive”. My ‘14 and current ‘18 use a (more standard/ automotive style) “red = positive, black = negative”… then throw in anything that’s been added on. You really need to check before guessing and hooking up. It is dangerous to to think or say things like “black is always ground”.
I think the brake breakaway switch will have one black wire most likely going to the positive battery post. The other black wire on the switch go's to the the brake wiring. All the brake breakaway switch I have seen have two black wires of maybe 14 guageDo you think that a couple of the wires go to a brake breakaway switch?
Everything connected! Everything working so far - battery not draining either. I have a photo a little above here with the final iterationJust wondering if you finally resolved your wiring issue. And got it all corrected? Just courious
