I finally installed the water filter
Discussion in 'My Favorite Mods, Tips, Tricks (and Blunders!)' started by silvermickey2002, May 30, 2010.
  1. silvermickey2002
    4,673
    476
    Sep 11, 2008
    Morris County, NJ
    Well, I finally had time to install our new water filter. Got the bracket from Camping World. Now the filter media is for reducing Chlorine (for taste & odor), Lead, Cysts, VOC (Chemicals), MTBE, Mercury, Asbestos, sediment and rust. It might sound like overkill, but according to the DW it is something to consider with all the ground water problems of today. She used to work for a pharmaceutical company and she dealt with water treatment. The filter is designed to last about 6 months with everyday use. That should take a few years while camping. It does not interfere with the bunk end support pole!
    Got everything from the Home Depot except the filter bracket
    Filter housing (GE - GXWH04F) $17.98
    2 - 2"x3/4 brass pipe nipples $9.30
    Female garden hose connection $4.41
    Male garden hose adapter $3.43
    Water filter (GE - FXUVC) $40.00
    RV housing bracket $15.00
  2. jabntam39
    jabntam39 Nothing like the smell of a campfire....
    36
    Sep 4, 2009
    PA
    Very nice...Where does that hose run into? Is that your main water line, or is it into your storage tank?Great idea though...
  3. PattieAM
    PattieAM New Member
    915
    Dec 13, 2007
    Nice job. I still use the blue hose filter ($25 ish) from Walmart. My coffee maker has a filter, and I have a Brita pitcher for drinking/cooking water if needed.
  4. silvermickey2002
    4,673
    476
    Sep 11, 2008
    Morris County, NJ
    The hose runs to the city water connection on the pup. Of course the other connection is from the CG connection. I placed a "Y" on the output side so I would have somewhere to fill a pot or bucket for water. Will get to test it out on Fathers Day weekend.
    We used a blue Walmart filter last summer and this spring and the filter put a smell and odd taste into the water. When we removed the filter the odor and taste disappeared. It might be a little on the pricey side and a little more setup time, but to us it's worth it.
    Thanks...
  5. Dusty82
    Dusty82 Active Member
    3,513
    Jun 23, 2008
    Northern Nevada
    This is not only a great idea, but I love the way you executed it. Yep, I'm bookmarking this mod for later use.
