I found a time capsule! (87 Sequoia)
Discussion in 'Checkout My Rig !' started by Evan Gaffney, Aug 27, 2019.
  1. BillyMc
    BillyMc Well-Known Member
    1,665
    987
    Mar 25, 2018
    Looks nice! Make sure it's sealed up tight, check bearing and tires, and go make memories.
    I'd check the voltage output from the converter before connecting modern electronics, some of the older ones didn't had very steady voltage. Mine will vary from way under 12 volts to 19 volts depending on load. I opted to just run off the battery with a smart charger connected.
