I need help with removing plywood from aluminum
Discussion in 'Roof/Floor Repair & Maintenance' started by AJDRAGON, Sep 5, 2021.
  1. AJDRAGON
    AJDRAGON New Member
    27
    Jul 23, 2021
    Puyallup Wa.
    Hi
    I am trying to replace the plywood on the rear aluminum sheeting, the old stuff is half rotted away, I am down to the last layer of the plywood, and the rotted stuff is coming off with a drill and wire wheel, but its the stuff that is not rotted that is putting up a fight. The wire wheel is taking ten times as long to go threw the good wood.
    Does anyone know of a better way to de-laminate the wood from the aluminum sheeting?
  2. Snow
    11,801
    2,380
    If the panel is completely off the trailer, a blow torch and a garden hose might work.. blow torch the wood.. or heat gun the aluminum..
  3. Tarkus
    Tarkus Member
    81
    59
    Aug 15, 2021
    Wyoming
    If that was mine, I'd leave the good wood alone.
    I'd get some thin hobby plywood (like 1/8" thick) and glue (Gorilla) it to the section where the wood has rotted off.
    The glue will expand filling any gaps.
    After curing for a couple days, sand the new wood to perfection. If done right, it should blend in nicely. You can also build up layers of thin plywood to perfection.
  4. AJDRAGON
    AJDRAGON New Member
    27
    Jul 23, 2021
    Puyallup Wa.
    Hi
    I'll remember that for when I'm redoing the front one, I got a lot removed using a belt sander with a 50 grit belt. I'm at the point now where I just need to spend a couple more hours with the wire wheel and it will be done.
  5. Overland
    Overland Well-Known Member
    475
    386
    May 1, 2013
    Bristol, Pa
    Paint scraper with a nice sharp edge.. i did my entire camper and beside the wire wheel/drill the scraper was the most effective.
  6. WrkrBee
    WrkrBee Un-Supported Member
    6,544
    3,450
    Sometimes an oscillating tool, with a scraper blade, works. A heat gun can be used to soften the adhesive.
  7. nitrohorse
    nitrohorse Active Member
    154
    106
    May 27, 2015
    NE Pennsylvania
    Be careful using any type of tool, especially a powered tool like an oscillating type. It's easy to damage the aluminum skin when using tools. I simply removed the rotted wood, squared off the undamaged area, and put a piece of exterior Luan in the space. I then used fiberglass cloth and epoxy resin to strengthen the butted joints. It turned out stronger than the original back wall.
