I need some HELP! Creative ways to remove decals.
Discussion in 'Miscellaneous Repairs & Maintenance' started by jberreth007, Oct 15, 2016.
  1. jberreth007
    jberreth007 Renoing our 91 Palomino TXL-LB!!! So much work!!!
    130
    Sep 21, 2015
    So, I'm In rhe process of removing the decals from my1991 Palomino TXL and as you can imagine they are weathered and brittle. I was able to take the center stripe off with a blow drier but I am having major problem with the rest. I have tried heat, a rotary disk eraser (which kind of worked but I used two discs on a two foot section), a product called Oops which removes the paint but not the decals, have also used combinations of all three! What ideas or suggestions do you guys have? There are a lot of stripes and lettering left and I need a technique that works!
  2. jberreth007
    130
    Sep 21, 2015
    BTW, the aluminum siding on my pup is textured which makes it difficult to use a scrapper and I suspect is what ate up my decal remover disks. It was like making shredded cheese.
  3. wastric
    wastric New Member
    22
    Jul 8, 2007
    get some 3M decal remover spray. It is available at Auto parts and paint and body supply houses. It is what the pros use to take off weathered decals and stripes off of cars. It softens the glue and helps the brittleness as well. It is safe for most paint types but always best to spot test it in an out of the way place 1st.
  4. oldcold
    oldcold New Member
    Sep 5, 2014
    I used a pressure washer to remove the decals on my 12 year old Jayco Baja, peeled them right off.
  5. jnc
    3,931
    1,186
    Oct 1, 2014
    South Central New Hampshire
    How about a wire wheel on a drill.
  6. fastlane
    fastlane Race cars, Boats and campers Oh my.
    Sep 23, 2016
    Howell, NJ
    i see you tried the strip it wheel. i have used them in the past with great success.
  7. MNTCamper
    MNTCamper Well-Known Member
    1,163
    381
    Jun 14, 2014
    MN
    Any PSA remover should work. I like the citrus based removers. Let it sit and soak in for a while and they should come off. You may need to wash again with the remover to all of the residual adhesive off, but they should come off clean and leave the paint intact.
  8. link81
    link81 New Member
    88
    Jul 27, 2016
    i second this idea
  9. noahnsteph
    noahnsteph New Member
    23
    Feb 21, 2005
  10. jberreth007
    130
    Sep 21, 2015
    This is the method I went with. It also stripped the paint but as I am repainting it is t that big of a deal. May require an extra coat to cover but was worth seeing the decals come off with ease!
    Ruikee likes this.
