Ideas for mounting a small lcd tv
Discussion in 'Campsite Electronics' started by luv2camp0314, Jul 25, 2010.
  1. luv2camp0314
    luv2camp0314 New Member
    123
    Jun 28, 2009
    Texas
    Does anyone have any ideas for mounting a small lcd tv or something someone has done??? [?:~{]
  2. NeedtoRoam
    NeedtoRoam Colorfull Colorado
    377
    Dec 29, 2008
    Centennial, Colorado
  3. FC
    FC Central Florida
    786
    Apr 2, 2007
    Apopka, Fl
    Great mod. Couple of questions.
    #1. Where does your antenna wire come in from the top?
    #2. Is the electrical plug in the roof or does the cord run thru the channel and plug in else where.
  4. jmcclung11
    jmcclung11 Active Member
    1,163
    Aug 10, 2008
    Fishersville, VA
    Nice job on the mounting of the TV. We are looking to buy a TV w/DVD player in it, so I will be looking to mount it somewhere!
  5. CarNutCass
    CarNutCass Put a little gravel in your travel
    805
    Mar 20, 2009
    St. Charles
    I bought a pair of the 9" headrest mounted monitors / DVD player. When bad weather struck and we were stuck in the camper, I temproraily mounted the dvd player monitor on the sliding handle of a rolling suitcase. Worked great and made it so that I could easily remove it and reinstall in the TV.
  6. NeedtoRoam
    377
    Dec 29, 2008
    Hi all,
    I installed a stainless steel wall plate on the outside wall near the furnace vent and routed the cable under the sink and up to the counter top just behind the sink/stove, just enough room to mount a double wall plate with 2 connections on it. Connection 1 on the wall plate is for a satellite signal coming from the dish which connects to a satellite receiver. I use channel 3 output of the receiver with a short jumper of cable coming out of the receiver to connection 2 on the wall plate which feeds signal to the TV.
    Connection 2 on the wall plate is routed through the floor under the sink, attached under the pop up to the floor and comes up in the storage for the table near the door and attached to the AC electrial cord, through the AC roof support brace and to the TV. This made for a clean install and the mount is a "under the counter" mount which allows it to swivel, tilt and fold up when the top comes down. No more transporting the TV back and fourth and free's up counter space. We love it!
  7. rjniles
    rjniles Active Member
    912
    42
    Aug 7, 2009
    Georgetown SC
  8. luv2camp0314
    123
    Jun 28, 2009
    Texas
    These are some great ideas, but where do you find the under the counter tv mounts? i have been looking and have had no luck [?:~{]
  9. FC
    FC Central Florida
    786
    Apr 2, 2007
    Apopka, Fl
    Bob did you cut into your frame to mount that outside box? [:!]
  10. rjniles
    912
    42
    Aug 7, 2009
    Georgetown SC
    Drilled a 5/16 " hole thru to rum the RG6 cable
  11. rjniles
    912
    42
    Aug 7, 2009
    Georgetown SC
  12. moonbayb
    moonbayb Member
    65
    Apr 19, 2008
    Upper Darby, PA
    Bob, I like your idea, but what are the screws ancored into in the ceiling? I'm sorry if this is a dumb question, but do pop ups have wood under the ceiling material? We have a 19" flat screen and have been looking for a better way to watch TV, other than placing it on the dining room table and craning our necks to view from our bunk.
    Pat
  13. rjniles
    912
    42
    Aug 7, 2009
    Georgetown SC
    See the anchors in the first pix in my photobucket. I used the plastic version with one inch pan head screws into my ABS roof. You mounting will depend on your roof construction.
    Just noticed you have a 2002 Bayside, so you also have a ABS roof. ABS skin outside, ABS skin for ceiling, foam core. You can use the same anchors I did.
  14. PATMD
    PATMD SOILENT GREEN IS PEOPLE!!!
    393
    Feb 16, 2009
    EDEN, NORTH CAROLINA
  15. FC
    FC Central Florida
    786
    Apr 2, 2007
    Apopka, Fl
    Good job Bob. Thanks for sharing. :)
  16. backyarddad
    backyarddad New Member
    507
    Mar 25, 2013
    Ok...sorry to bump an old topic...but has anyone else put a TV in a PUC? Did it work well?
  17. Harvardroger
    Harvardroger If it feels good, do it! If it hurts, Stop!
    576
    19
    Sep 5, 2011
    Right outside our Pup we get 3D HiDef reception. So real you can touch it [:D]
  18. Raycfe
    17,819
    3,298
  19. austinm48
    austinm48 http://s1174.photobucket.com/albums/r604/austinm48
    298
    Dec 5, 2011
    I put a 15 inch LCD flip down tv on my ceiling.... The same people mount in their vehicles ..... And its even 12 v...... And I used a 12 v DVD player too so I can boondock and still watch movies
  20. backyarddad
    507
    Mar 25, 2013
    Where did you get the vanity mate? How is it hanging from the top?
