In need of a bedding solution..
Discussion in 'Cushion, Curtains, Carpets, Bedding, Clothing Stor' started by Overland, Jan 25, 2020.
  1. RobertZ
    RobertZ New Member
    Dec 4, 2017
    Alpharetta, GA
    Have you found your mattress solution? Since the post is "fairly" recent I thought I would add my 0.02. I recently bought 5" queen and king LUCID brand memory foam mattresses for our HW from Amazon. They are SO MUCH better than the prior 4" mattresses. I just used an electric fishing knife to cut the memory foam down about 3" on one side to make it fit our bunk ends. It was one of the best things I've done for our camper!
  2. mk4
    mk4 Member
    87
    65
    Nov 20, 2014
    I would say most trailer mattresses before 2010 or so were pretty disappointing. Medium firm 4" foam. I'd say max capacity was about 150 pounds. Bottoming out was common. The best solution is to replace it with a hybrid foam mattress. 1" rigid foam, 1.5" firm, 1.5" medium.
    Gypsywolf likes this.
  3. Hogeyphenogey
    Hogeyphenogey Member
    76
    May 3, 2014
    I have the same camper. I went and got a memory foam mattress from Walmart and used an electric Bread knife and cut it to fit. Works like a charm
  4. Overland
    Overland Well-Known Member
    368
    280
    May 1, 2013
    Bristol, Pa
    Sorry I hadn't replied earlier..
    So, I mentioned above about really liking the gel infused memory foam on my bed in the house, only drawback is it can get stiff or hard in colder weather. But after a few minutes with body heat you tend to sink inside it..
    Anyway, the Mrs had removed the sheets for washing the other day, and the pup decided he needed to chew on the corner tearing pieces off. So that's settled, i'll be trimming that one to fit in the camper. I'll do so as soon as we have a few days without rain forecast, get a couple things done.
    Thinking about heading to West Virginia when things open up if sooner than later. Hoping to salvage a western trip later this season.
    gladecreekwy and Sjm9911 like this.
