Indoor Caulk recommendation
Discussion in 'Miscellaneous Repairs & Maintenance' started by Riveyman, Feb 2, 2017.
  1. Riveyman
    Riveyman Member
    294
    Apr 15, 2014
    NC
    Did some remodeling on the bathroom and re-caulked everything with DAP bathroom caulk. Well, noticed that it has completely dried out and cracked. Either from the extreme heat or cold. Probably both.
    Anyone with experience recommend something? What was in there before the remodel was real rubbery like. What would that be?
    Thanks all
  2. Dubbya
    6,129
    64
    Aug 2, 2011
    Steinbach, MB
  3. sea-piner
    sea-piner Member
    400
    Oct 9, 2015
    Silicone caulk will work best for bathrooms and lasts much longer--it is just harder to clean up and the crap goes everywhere. What I do inside the home (haven't had to do anything with caulk on the inside) is: use masking tape about 1/8 to 1/4" from seem. place a bead just big enough to fill about 1/2 that space. Use finger (with a little Vaseline to prevent drying and cracking of your skin--I prefer the Vaseline over gloves as I like to be able to feel what I am doing) to force into seem and create a good concave surface. then lightly wipe with wet sponge. Remove tape when tacky.
  4. Adam H
    Adam H Active Member
    485
    184
    Aug 22, 2015
    synkoflex, inside and outside
    Adam
  5. nomorecoop
    nomorecoop Member
    454
    Jan 8, 2012
    I had issues with my shoilet walls separating (only held together by caulk).
    Found that construction adhesive (used for gluing shower walls to sheetrock in bathrooms) followed by a bead of silicon (for flexibility) seemed to be the strongest hold.
  6. Riveyman
    Riveyman Member
    294
    Apr 15, 2014
    NC
    Thanks everyone,
    We put up the plastic walls in the "shoilet" haha. There was nothing there before. All the caulk I put on to seal in the edges has dried and cracked. I will have to get some silicone caulking and redo it.
    Any recommended brand?
