Inside of Tire Tread was Gone
Discussion in 'Tires / Brakes / Bearings / Axles' started by tork65, Jul 14, 2017.
Tags:
  1. tork65
    tork65 Member
    81
    Mar 23, 2012
    So I just returned from a 6412 mile trip from NC to Yellowstone to Grand Canyon and back. About half way I was checking the tire pressure and doing an inspection over everything and I noticed that the inside of the tire tread was gone, no tread left. I assumed from the beginning I was over weight as I only had so much room in the back of my pickup and the camper I have (2006 Fleetwood Niagara) only allows for about 280 pounds or so loaded in the camper. I had two coolers each weighing about 80 pounds, food, charcoal... and so on, I have no idea what I weighed, but I knew I was over. I ended up getting new tires (it was time anyway) and made the trip without incident. Anyway, is there any solutions for getting the allowable weight in the pup increased for supplies? Do I have to do an axel swap? Can I just up grade to a heavy duty tires? Any suggestions would be a great help. Thanks.
  2. sierrapup
    sierrapup Active Member
    373
    38
    Jun 19, 2016
    possible helper springs..??? [CC]
  3. tork65
    tork65 Member
    81
    Mar 23, 2012
    Yeah, thats not a bad idea. I had not considered that.
  4. f5moab
    1,421
    471
    May 7, 2013
    Somewhere in Idaho
    Adding different springs will not allow more load just like in a truck it will keep it from lowering from the added weight (the springs connect to the axle). The weight of the trailer is still going to be held by the axles, tires and the tongue weight, and most likely the type of frame (C-channel or full), and flooring.
    So I guess changing the axle and tires might help, but would the flooring/frame hold the extra weight
  5. mstrbill
    mstrbill Active Member
    694
    149
    Mar 17, 2013
    Austin , Texas
    then you need go weigh it and find out how much you are over your GVWR. Your CCC is 610lbs, but you have to subtract propane, battery, awning and AC from that.
    You will have do more than change the axle; change the springs, and probably the spring hangers. And maybe go to an overslung axle to allow bigger tires.
    Some how Fleetwood increased the CCC to 810lbs for my 2008 Niagara.
  6. tork65
    tork65 Member
    81
    Mar 23, 2012
    Yeah I knew I would need to weigh it in order to find out I was over, but it wouldn't of mattered. The TV was full and I had things I still needed to pack, so I just went for it.
  7. Adam H
    Adam H Active Member
    531
    218
    Aug 22, 2015
    There is a thread here where someone did an axle upgrade on his Niagara and he did a really good job! Might be with the read as the Niagaras at at it near their max axle weights when empty.
    Adam
  8. arthuruscg
    arthuruscg Active Member
    1,363
    Nov 14, 2012
    You will need to swap the axle, springs and tires to increase the carrying capacity. Coleman's use boxed frames/
  9. 1380ken
    1380ken Well-Known Member
    2,589
    996
    Nov 7, 2013
    Mass
    Are you saying that driving 3000 miles with the trailer overloaded wore the inside tire tread off? Were the tires good at the beginning? Did the new tires also loose the inside tread on the other 3000 miles of overloaded driving?
  10. Halford
    Halford Well-Known Member
    3,563
    570
    Sep 28, 2011
    Santa Clarita, California
    Carry stuff that you WILL use, leave those at home that you WILL NOT use.
  11. etrailerJohn
    etrailerJohn Member
    96
    Apr 19, 2016
    Wentzville, MO
    There's more than one possible cause of the wear you describe. Overloading the trailer will indeed do it, but also if an axle 'flip' has been done incorrectly, it can also cause the wear you're describing. 'Flip' is kind of a misnomer. What you're doing is relocating the suspension from below the axle to above it. The axle isn't flipped around side to side, because doing so would cause the arch intentionally manufactured into the axle to become a dip.
    Keep in mind that upgrading the axles, suspension and tires/wheels won't necessarily increase the camper's weight bearing capacity. You'll still be limited by the GVWR of the trailer.
    You can see more information by clicking the link below:
    https://www.etrailer.com/expert-120.html
