Installed roof support braces for a/c
Discussion in 'Heating / Cooling Systems' started by smoreking, Apr 29, 2012.
  1. smoreking
    smoreking Member
    400
    Sep 15, 2009
    Small Town, Middle TN
    My 2004 Rockwood already had support molded into the roof but I don't think they were enough. I had a dip and I was worried that it would get worse or pool water. I ordered braces from rv dealer and installed them myself. Here is before picture:
    [​IMG] here are the braces:
    [​IMG] installed photo
    http://he/2.2.3 (CentOS)
    X-Powered-By: PHP/5.3.10
    Content-Length: 52
    Connection: close
    Content-Type: text/html; charset=UTF-8
    OKAY: http://img.tapatalk.com/603d938a-48fb-3956.jpg finished result
  2. gec66
    gec66 Active Member
    924
    43
    Sep 24, 2010
    Good job! Preventative measures taken before a real problem exists gives much peace of mind, doesn't it?
    It also can save tons of headaches and cost down the road.
  3. CampingCindy
    CampingCindy New Member
    90
    Mar 25, 2012
    Did the braces go inside the roof? Mind if I ask for a ballpark cost?
    I need to get some support inside my roof as it's totally sagging and scary, but I'm avoiding starting the whole process, including research, because it seems overwhelming and costly.
  4. smoreking
    smoreking Member
    400
    Sep 15, 2009
    CampingCindy, The cost was 61.00 for the braces plus 27.00 shipping to my home. I live in a really small town so we don't have a dealer here. If you ordered from local dealer, you could pick it up and avoid the shipping. I removed the a/c to allow the roof to go to normal position while installing the braces so I also replaced a/c gasket at cost of 21.00. It was pretty easy to do. I held the brace while my wife drilled hole for bolt, once I bolted that side we went to other side and pushed up on the end of the arched brace, drilled another hole, and bolted it in. I don't think you have to remove a/c to do this, but it would be harder to push the roof up to shape with the extra weight on there.
  5. smoreking
    smoreking Member
    400
    Sep 15, 2009
    Just realized, I can't see one of my pics. Here is a pic of the braces installed inside the roof on each side of a/c.
    Content-Length: 52
    Connection: close
    OKAY: http://img.tapatalk.com/603d938a-be71-1d4b.jpg I pulled curtain down and bolted right through sideboard
  6. bonusbuilt1950
    bonusbuilt1950 New Member
    74
    Mar 22, 2011
    Can you tell me the length of the braces? They look like they'd work in most any pop up. I need a width of 83 inches. I don't have ac, bu8t my roof sags and I want to get it back to normal before I put the Elastomeric paint coating on it.
    Barry
  7. mdigby
    mdigby New Member
    279
    Sep 9, 2007
    looks good. The saying goes... an ounce of prevention is worth a pound of cure!
  8. CampingCindy
    90
    Mar 25, 2012
    Is there any curve to them? I'm wondering if a 2x4 would achieve the same result? I don't have an AC, just a damaged roof, and nobody good and affordable to fix it up right.
  9. smoreking
    smoreking Member
    400
    Sep 15, 2009
    Barry, I will have to measure them and get back to you tomorrow. I think you are right about them fitting a lot of different models. Yes Cindy, they do have a curve in them. I would say anything you could use to give your roof some support if sagging would be better than nothing.
  10. CampingCindy
    90
    Mar 25, 2012
    I don't mind spending more money to do it right (as right as I can without tearing the roof apart that is) I just wanted to make sure there was some sort of curve.
    Thanks!
    Good job being proactive, you don't want your roof ending up looking like mine!
  11. smoreking
    smoreking Member
    400
    Sep 15, 2009
    yeah, I can see you definitely have a problem. The braces are made to curve in an upward direction. If you used them, you would have to get the ceiling pushed up to level. Good luck in whatever you try.
  12. smoreking
    smoreking Member
    400
    Sep 15, 2009
    Barry, the width of the braces is 83". Also where the two ends of the brackets bolt on there are slots so there is minor adjustment.
  13. bonusbuilt1950
    74
    Mar 22, 2011
    THey look like they'd do the job for me. Too bad the RV places I've been to all give me a blank stare when I ask. No one seems to advertise them online when I search. The Viking people were not any help either. I may have to improvise. I've even thought of using metal fence posts for wire fencing. Taking off the flat piece near the end and removing the hooks. Painting them white and making side brackets. We.ll see..........
    Barry
  14. smoreking
    smoreking Member
    400
    Sep 15, 2009
    Barry, I don't have any part numbers, but if you call this phone number and ask for Martha I'm sure she can help you. She asked for my vin number and called me back with a price later that day. If you really want a set I'm sure she will help and ship them to you....Bankston RV Huntsville, AL. (256-533-3102).
  15. StoutHokie
    StoutHokie New Member
    Feb 27, 2012
    Thanks for the Info Smoreking! Looks great.
  16. bonusbuilt1950
    74
    Mar 22, 2011
    OK, let me call her................
    Thanks,
    Barry
  17. jab2181
    jab2181 New Member
    931
    Jul 4, 2012
    looks great, I am going to call my dealer today. I would rather spend the money and get these. Thanks for sharing!
  18. cfmx
    cfmx New Member
    282
    Jun 21, 2012
    That looks great!
    I would like to do the same for our Fleetwood camper which also has a slight dip in the roof. The bar looks identical.
    I called the local Rockwood dealer and told him I have a Rockwood camper (because I know I wouldn't get the time of day if I told him it was for a Fleetwoood). He asked if we bought the camper thru LazyDay Rv and I said no. Because we of that he said Rockwood wouldn't allow him to lookup parts w/out the last 4 digits of the VIN. Sounds crazy to me. Why would they need a VIN number to sell parts??
    Anyone willing to share last 4 digits of VIN? Along w/ model number. [?:~{]
    I would like to buy local but may be forced to have it shipped. We have the AC unit already off the camper getting ready to do roof work. Would be a great time to add another support.
  19. smoreking
    smoreking Member
    400
    Sep 15, 2009
    I guess I should post that the dealer I named above with the telephone number is where I got my braces, but I have since been messaged that Martha is no longer available and the other parts personnel have been unable to help some.
    I think that if anyone needs these braces they can be found by calling a few different dealers and just asking for them. I think they are pretty universal in lenth and would likely fit many different brands.
  20. Tracker51187
    Tracker51187 New Member
    62
    Sep 30, 2012
    If so many people have this problem, why don't they install them at the factory?
