Installing 12v Plug
Discussion in 'Campsite Electronics' started by Stoosh, Mar 17, 2013.
  1. Stoosh
    Stoosh New Member
    Jul 18, 2010
    I would like to install a 12v plug in my Pup. The plug will go directly to a second battery and be used with an inverter for a few items while dry camping.
    Do I just wire the plug directly to the battery? Is there a need for a fuse?
    Just wondering if anyone has done this and if so, how?
    Thank in advance
  2. Clive
    Clive New Member
    281
    Feb 18, 2013
    I would use an inline fuse rated the same or just a little lower than the amperage of the inverter.
  3. ghacker
    ghacker Active Member
    3,438
    Nov 8, 2009
    Yes, put a fuse in. If there was a direct short, somethings got to give. It will either be the device plugged in or the wiring would melt. If you can find the right one, there's also resetable breakers available. They are pricey.
  4. bondo54
    bondo54 Active Member
    1,489
    24
    Aug 15, 2010
    A big YES on a fuse. Fuses are cheaper than electronics.
  5. tombiasi
    5,365
    1,001
    I assume you mean and outlet. Anything taken directly from the battery should be fused as close to the battery as possible. The fuse rating should be lower than the wire and outlet rating. Keep in mind when using an inverter, the battery will be supplying 10 times the current that the device load takes from the invertor.
    Tom
  6. Yak
    Yak Well-Known Member
    1,204
    86
    Apr 18, 2009
    A fuse close to the battery. A fuse is used to protect the wiring.
