Installing a new roof vent or skylight
Discussion in 'PopOut (Hybrids)' started by SlavCo, Jul 15, 2016.
  1. SlavCo
    SlavCo Member
    54
    Mar 16, 2016
    Hey all,
    Has anyone installed an additional roof vent or skylight in their hybrid? I find it to be a bit dark inside and would love to bring in some additional daylight into the camper. I've been thinking of installing a skylight or even an extra roof vent in the front of the trailer to remedy that. Has anyone attempted this before?My biggest concern is not knowing where the aluminum support beams are. I wouldn't want to cut into the roof smack in the middle of a bean [:O]. Any idea if a regular stud finder (like you use in the house) would be able to accurately detect the aluminum beams?
    Thanks in advance for any tips/suggestions here.
    Slav
  2. jacrabbitt
    jacrabbitt Active Member
    234
    51
    Mar 27, 2015
    Michigan
    Know it's an od post .But often wondered the same.
  3. eprovenzano
    eprovenzano Member
    507
    19
    Oct 6, 2013
    I've not, but I did put an A/C unit on my pup... I can't see this being any different than adding a vert or skylight to a standard TT.
  4. ronnie
    ronnie Member
    121
    Sep 3, 2015
    funny thing was just thinking the same, but i replace my vent with and ac but now relies that the vent was a big part of venting the camper, now we have to run the ac or a little fan at night, so i was thinking about adding a vent in a different spot which has no bracing for it. So what i am wondering if i cut out the roof for the vent and then put 4 piece of wood to help brace the vent would that hold up..
    sorry for hijacking your post but figured it would help both of us..
  5. SlavCo
    SlavCo Member
    54
    Mar 16, 2016
    No worries :)
    I never got around to doing this yet, but I did try using a stud finder to see if it would locate the aluminum beams - unfortunately it didn't work :( The stud finder would just randomly beep in all sorts of places, making it unreliable. We'll see, maybe in the spring I will take this idea up again.
    Cheers
  6. yetavon
    3,403
    229
    Mar 11, 2010
    Western NC
    I know its been done on a Forest River hybrid. seen the pictures, made a huge difference and seriously considering adding on to ours after the warranty runs out. If I remember correctly, they had on the heat on a cold damp day and located the studs by the condensation.
  7. PaThacker
    PaThacker Well-Known Member
    1,404
    305
    Feb 11, 2010
    Poconos
    I'm putting a fantastic fan into the non powered vent on my Jayco this winter. Rip out the junk. And sandwich in a new vent. I'll post a picture so you can see the roof structure of pups.
    Rip out the bathroom fan on your hybrid to see the construction of the roof studs.
  8. SlavCo
    SlavCo Member
    54
    Mar 16, 2016
    Brilliant! My ceilings are not smooth, they have that stucco texture, but still worth a try come early spring .. Thanks!
  9. SlavCo
    SlavCo Member
    54
    Mar 16, 2016
    I'm pretty certain I know how the roof is constructed, my concern is location of the aluminum studs. Unfortunately they're buried within the luan/styrofoam sandwich making it difficult to predict where they are. When I was replacing the rotten floor this past summer, the floor studs were in random places.. nothing like the 16" on center I'm used to in home building :)
  10. SteveMM
    SteveMM New Member
    Aug 26, 2016
    I saw a guy posted a video about his skylight install on another forum just the other day. Here's a link to the video: https://youtu.be/1yw7sMAeokM
    He made it look pretty easy.
  11. SlavCo
    SlavCo Member
    54
    Mar 16, 2016
    Thanks Steve, it doesn't look like a tough job at all. One luxury he had was the plans from Jayco to show him where the ceiling studs are :) That's the one piece of puzzle I'm missing! I doubt I will be able to get this sort of information for a 13 year old trailer.
  12. SteveMM
    SteveMM New Member
    Aug 26, 2016
    Can't hurt to ask. I'd call Jayco.
  13. SlavCo
    SlavCo Member
    54
    Mar 16, 2016
    I've emailed them yesterday, we'll see what they come back with... here's hoping! :)
  14. SlavCo
    SlavCo Member
    54
    Mar 16, 2016
    Sooo a bit of a Christmas miracle! StarCraft did respond and provided me with the roof construction drawings! I must say, I'm pretty impressed that they 1. Responded and 2. Still had the plans available.
    The other miracle that happened earlier this year was that I (225lbs) did not fall right through that roof! There is no support bracing through out the entire front portion of the roof... crazy!!! The roof did seem solid though when I was up there.. anyway, I will now take some precautions when I get up there to install the skylight this spring, can't wait!!!
    I've attached the drawing StarCraft sent in case it helps anyone else - assume it's the same specs for Antigua model as well.
    Cheers and Happy New Year!
    Slav
  15. SlavCo
    SlavCo Member
    54
    Mar 16, 2016
    Sooo... I ordered my new skylight, 18" x 24" some time ago, and now that the weather improved I was finally able to install it! It makes a huge difference in how much brighter the inside is! Overall a fairly simple job, the only added complication is I need to MacGyver something for the inside trim as I was not willing to spend another $100+ USD for the plastic garnish. Also, one other minor snag was cutting through the wires which feed one of the ceiling lights, simple enough to fix, just one more thing I need to fix :) image1.JPG image2.JPG image3.JPG image4.JPG image5.JPG
    cma7777 likes this.
  16. Snow
    11,163
    1,827
    Looks good... for the inside trim you might be able to use some fairly thin molding trim and use something like guerrilla glue to hold the pieces in place..
  17. Davylee
    Davylee Camping = Life is Good Gold Supporting Member
    1,791
    126
    May 4, 2009
    Maine
    Nice work. pics of the inside with the natural light?
  18. SlavCo
    SlavCo Member
    54
    Mar 16, 2016
    Will take some soon! Have a trip coming up next weekend so hopefully there will be plenty of opportunities for pics :)
  19. RFryer
    RFryer Hopkinton, MA
    762
    Mar 10, 2009
    Hopkinton, MA
    Any inside pics yet? I'd love to do this mod.
  20. SlavCo
    SlavCo Member
    54
    Mar 16, 2016
    I'll take some for you today, I just finally got around to doing the inside trim - stay tuned! :)
