installing ceiling hooks?
Discussion in 'Roof/Floor Repair & Maintenance' started by lukenick, Aug 2, 2014.
  1. lukenick
    lukenick New Member
    76
    Sep 16, 2013
    I bought some of those hooks you can screw in. How can I secure those to the ceiling? Stupid question but is there a beam or something I can screw into? LOL (female here)
  2. Ryanincc
    2,275
    Dec 28, 2013
    Corpus Christi, TX
    Personally, Ive gone to some lengths to avoid screwing anything into the roof. Its probably up for some slight debate, but I wouldn't screw anything into the roof.
  3. GMD
    GMD Member
    482
    Mar 18, 2014
    I agree, I wouldn't either.
  4. swordfish
    swordfish Well-Known Member
    2,209
    37
    Sep 27, 2010
    If you Velcro a piece of wood strip to the ceiling then you can screw in your hooks to the strip.
  5. pixel
    pixel Campers: Nature's way of feeding mosquitoes. Unkn.
    447
    May 4, 2008
    Massachusetts
    First off, no stupid questions on the portal!! So please ask away!!!
    Second, ditto about not wanting to attach anything to the ceiling. The roof/ceiling is one of those funky items that if you look at it wrong, problems arise. It is better to avoid any problems, instead of creating them.
    My question for you, is what are you trying to accomplish? That might help us help you better. : )
    Pixel
    Ps-there are many of us ladies on the portal!!!!! [;)]
  6. lukenick
    lukenick New Member
    76
    Sep 16, 2013
    Just looking to hang a shelf or shoe organizer or pots and pans. Looking to get rid of the clutter on my counter tops.
  7. Unstable_Tripod
    14,279
    35
    May 20, 2008
    Seattle, Washington
    I join the others in saying that it is best to avoid screwing anything into the ceiling. If you want shelving check out the mods others have made with shelving based on spring-loaded poles that run from floor to ceiling. Do some searches. There are many ways to add shelving without creating potential ceiling leaks.
  8. turborich
    turborich Active Member
    1,908
    Jun 22, 2010
    Las Vegas, NV.
    I also would avoid screwing into the ceiling if you can.
    If you're dead set on doing so then I would use one of the U shaped hooks that is attached to a square metal plate. It mounts with 4 screws, I would also use very short screws and a dab of liquid nails or similar between the metal plate and the ceiling. [2C]
  9. geoanna
    geoanna New Member
    75
    Jul 14, 2013
    As you can see the theme here... [:D] Don't screw anything into the roof that isn't meant to either hold it up or hold it together. [:D] There are a number of great ideas for shelving. Do a search through the forum. You can use any of the soft collapsible closet shelves. You can use your shepard hook (if the contents aren't too heavy), or even a pressure shower rod.
  10. adrianpglover
    adrianpglover Active Member
    1,482
    Jul 8, 2014
    Texas
    Along the same theme here, what about using something like a command hook? Don't know if there's a specific one for this application, but worth a look, IMHO.
  11. Ken1967
    Ken1967 Can't wait to Camp!
    1,071
    Apr 9, 2010
    Well our camper came with things already screwed into the ceiling. Light fixtures, catches to hold the door up, hooks for hangin kitchen shelving.... so I would say you should be able to screw hooks in. Follow the stud lines where other items are screwed in and use fairly short screws.
  12. lukenick
    lukenick New Member
    76
    Sep 16, 2013
    what are "shepard hooks". The only things screwed into my ceiling are just like you said the door track and the lights. I do not have any hooks for kitchen shelving which is why I wanted to add some. I looked into the Command sticky hooks but they are meant for walls so hanging those up on a ceiling won't work.
  13. geoanna
    geoanna New Member
    75
    Jul 14, 2013
    Sheppard Hooks are the poles that extend out over the bunk ends to hold the canvas up. Typically attaches to another curved pipe that makes the bowed end.
  14. Ryanincc
    2,275
    Dec 28, 2013
    Corpus Christi, TX
    I think they mean shepherd poles, which are the poles that hold the canvas up over the beds. You can hang light stuff from those like a place to put your glasses when you sleep. But you're looking for shelving it sounds. Pinterest actually has a lot of pics of different shelving systems that can inspire you or just searching around here. The tension rod, or metal shower rod, shelves are popular. I did other types of shelves like putting zip ties through the rook support braces to make a loop to hang closet organizers from and I used the door tracks to make a shelf. You can click on my imgur link in my signature to see what I did. You can also buy collapsible clothing rods that you can mount to the ceiling with automotive double sided molding tape to have a place to hang a closet organizer. The different ways you can do it seem endless. And it's fun to do. Happy Hunting :)
  15. geoanna
    geoanna New Member
    75
    Jul 14, 2013
    Ooops [:O] Pole not hook... [:!]
  16. Phranc
    Phranc New Member
    683
    Apr 9, 2014
    Yeah, you shouldn't be trying to hook those sheep you are counting to get to sleep! [LOL] [LOL] [LOL]
