Intermittent power from converter
Discussion in 'Wiring' started by sanrico, May 7, 2019.
  1. sanrico
    sanrico New Member
    28
    Jun 16, 2014
    Hi all, I opened the PU this weekend to get it ready for the season and discovered an odd power problem: When I plug in to shore power (no battery connected) and try turning on the interior lights, they flash on and off and never stay on.
    In addition, the propane leak detector alarm (which usually beeps once when I unplug from shore or the battery) beeps every couple of seconds along with the flashing interior light.
    With the flashing and beeping, it appears that the converter is sending out intermittent power. I checked the fuses and they are fine. I also reset the breakers.
    My question is: Does this mean the converter went bad and I have to buy a new one? Or is there some sort of reset procedure I can try?
    Any info would be greatly appreciated. Thank you!
  2. tombiasi
    5,711
    1,327
    Sounds like your converter has some problems.
    Could be there is a load on the system the converter doesn't like.
  3. nineoaks2004
    7,750
    3,404
    Dukes, Fl
    Try putting a battery in the unit and see if that cures the problem. The battery can stabilize the load on the converter.
  4. tombiasi
    5,711
    1,327
    If the battery does do that then I would look closer at the converter.
  5. sanrico
    sanrico New Member
    28
    Jun 16, 2014
    Hi folks, just to close this thread, it ended up being a bad converter. I tried all kinds of fixes, but finally ended up replacing the converter.
    ...and then the camper was stolen. I'll start a thread about that.
  6. neighbormike
    2,541
    2,031
    Oct 6, 2012
    WI
    I already replied to the other thread, but my suggestion (now) would be get a different converter installed in a new camper! [:)C]
