Is a Pop-up right for me?
Discussion in 'Camper Pre-Purchase Questions' started by Drbean, Feb 13, 2018.
  1. SteveP
    SteveP Well-Known Member
    1,666
    492
    Nice floor plan. I can't make out a model number in the pics. Nada shows 2 8 ft models in 2003
    Freedom Series
    M-1610 17' 7'1" 1574 6
    M-1620 17' 7'1" 1336 6
    http://www.nadaguides.com/RVs/2003/Rockwood
    BTW that's unloaded weight
    The 1610 seems a little heavy but the 1620 would be about avg weight for the 8 footers I looked at in that year range.
    I think you'll appreciate that sofa.
  2. Drbean
    Drbean Member
    30
    Feb 13, 2018
    I'm heading out to check it out. I think tow package is optional but I have a hitch and lights at least.
    Will send pics if I pick it up
  3. gardenbliss
    gardenbliss Well-Known Member
    1,298
    147
    Dec 9, 2013
    San Diego
    UHaul installed hitches on 2 of my TV's over the years, and I've never had a problem. We checked with the dealerships and the SUV/Mini Van manuals and it was all good.
  4. Drbean
    Drbean Member
    30
    Feb 13, 2018
    Well I went ahead and picked it up!
    Can't wait to do more research on it and get more familiar with everything. Not only have I never had an RV, but I've also never dealt with gas appliances. I don't even know how to test a carbon monoxide detector!
    So I'm looking forward to getting through some of the basic stuff and learning how it all works.
    I will post pics soon, it was well past dark by the time I got home.
    Orchid, Jorja and tzmartin like this.
  5. gardenbliss
    1,298
    147
    Dec 9, 2013
    San Diego
    All of the information you need, and then some, is in this Portal. Welcome to our family of PUP enthusiasts.
  6. jnc
    3,931
    1,185
    Oct 1, 2014
    South Central New Hampshire
    I figured you got it because the CL post is gone! as for The Carbon monoxide detector you could probably just replace it because they dont have a long shelf life and this way you will know how old it is and when to replace it again. The gas appliances are simple to deal with. when you go to use them hookup the propane turn it on. goto the stove turn it on. Wait a few seconds With a stick lighter start trying to light it. It may take a few times to light because the air in the lines needs to bleed out. After you get this far than play with the fridge & furnace. Good Luck & camp on [put&pu] P.S. We will be anticipating the pic's
    Drbean likes this.
  7. DJS12354
    DJS12354 Well-Known Member
    1,578
    499
    Sep 21, 2017
    Camp Driveway time!
  8. Drbean
    Drbean Member
    30
    Feb 13, 2018
    Thats good advice.
    I read something about these carbon monoxide sensors actually controlling the flow of the gas. So if it malfunctions or detects gas it won't allow the flow. Pretty interesting and I don't know if that's how mine is yet, but I wonder if I would need an OEM replacement or is that pretty standard
  9. Drbean
    Drbean Member
    30
    Feb 13, 2018
    Hey that's not a bad idea! I should stage it in my back yard and camp out there this weekend! What better way to get to know everything
    Jorja and jnc like this.
  10. DJS12354
    1,578
    499
    Sep 21, 2017
    I am looking forward to doing that in another month or two to re-introducing myself to our pup!
  11. myride
    myride Well-Known Member
    985
    464
    May 14, 2015
    Edmonton, AB
    Congrats on the NTU trailer....lots of great times ahead!
  12. jnc
    3,931
    1,185
    Oct 1, 2014
    I doubt very much that your pup has the type that shutoff the gas! and what ever you get will work. You my want to measure yours and try to find one to fit the hole.
    Drbean likes this.
  13. BikeNFish
    BikeNFish Well-Known Member
    3,386
    2,293
    Apr 24, 2017
    Maplewood, MN
    Congrats on your NTU pup.
    Drbean likes this.
  14. Drbean
    Drbean Member
    30
    Feb 13, 2018
    After looking around, I notice a lot of acronyms around here. I'm pretty decent at figuring them out because at my job half our sentences are spoken in acronyms. But NTU means new to u right?
    Btw thanks! Really stoked about it :)
    Goodbye (or good riddance) tent camping.
  15. myride
    985
    464
    May 14, 2015
    Edmonton, AB
    Indeed it does.
  16. Drbean
    Drbean Member
    30
    Feb 13, 2018
    As promised, here's some pics!
    https://imgur.com/a/IO4vg
    So nothing ever looks as good in person as it does in the pics. The floor is solid and all the furniture is in good shape. The canvas seems good although there is some wear and tear noticed near the parts where you push the canvas ceilings out with the pole (looks like someone could have been too aggressive with the poles or maybe just normal wear marks) but nothing that would cause a leak, just an area of concern. The poles also seem to take a tremendous amount of pressure to hook in so I may drill an extra hole to collapse the pole down one more notch to make this easier. It seems like the canvas maybe shrinks slightly over the years.
    The door also has an issue where the latch doesn't quite catch when the 2 door pieces are clipped all the way together. When the little clip under the window is left loose, it will latch.
    The main thing concerning me is on 2 or 3 of the extension poles supporting the roof, the 2 bolts at the top seem to have broken through the outside paneling. This wouldn't cause any leaks but I am going to have a closer look to see if this could lead to any sort of binding or alignment issues with the roof and crank system. I may need to take a closer pic to show what I mean.
    So biggest thing is, I am putting a lot of faith in the guy who sold it to me. They seemed like honest folk and it was priced well but you never know. I could not test any of the electric or gas. They didn't have a way to plug in the 30 amp plug at their house, and no propane. I am getting an adapter for the plug (I know I won't be able to turn everything on at the same time with a 15 amp breaker) and will refill the propane and test anything I can this Saturday. Some electrical might need a bit of work for DC power as there is a bit of rigging going on near the tongue area. Electrical isn't my specialty but I can make tidy connections and learn a thing or two. The only thing I have actually tested so far is the sink, and that was under hose pressure, which worked with no leaks. Mostly I'm suspicious of the gas system, seems they didn't use any of the gas appliances although I think they said they used the outside gas hookup for a grill but I don't remember. Oh yeah, I think this model comes with an outside grill option, it has the mounting rail for, but it wasn't included in the transaction.
    Regardless the outcome this weekend I think this will be a great entry to pup camping.
    Edit: I accidentally attached one of the pics to this message but the rest are in the imgur album linked above.
    Orchid, shuang2 and mrkrag like this.
  17. jnc
    3,931
    1,185
    Oct 1, 2014
    It looks pretty good. On the lift pole bolts you want to check for water damage/rotted wood. The doors on pups can be a pain if the pup isnt level.
    Drbean likes this.
  18. Jorja
    Jorja Active Member
    119
    44
    Oct 6, 2017
    Delaware
    Congrats!
    The pictures are great. And good luck with Camp Driveway, it definitely helped us sort out a few issues.
    Maybe the owners just didn't like cooking smells inside the pop up, as to why they didn't use the inside burners?
    I'll sometimes heat up things in the microwave in ours, but we do our main cooking outside, even with burners and an oven inside.
    Drbean likes this.
  19. Drbean
    Drbean Member
    30
    Feb 13, 2018
    A small microwave would be a good addition.
  20. mpking
    mpking Well-Known Member
    1,367
    363
    Jun 17, 2014
    Raynham, MA
    @Drbean Looks good! I have a similar Rockwood.
    If the sideboard has rotted out, people fix them all the time. People have even ordered replacements from the factory. The part is cheap (I think it was like $40). But shipping was a killer.... (Like $200) I think based on other posts your in South Carolina, and the factory is in Indiana, so it's probably not a good fit.
    But there are many threads on fixing that. Get some pictures, and we'll all offer advice.
    Since I think your in SC, here's another accessory you might want. It's a Mud Dauber Screen for the furnace. It a screen that doesn't let nest building insects into the Furnace exhuast port. I'm guessing the model furnace you have based on the picture, so you might want to research if it's the correct one before you buy it.
    http://a.co/aIqJyiK
