Is it ok to leave full propain bottle on while towing?
Discussion in 'First Time & New Camper Owners' started by sharkman987, Jun 3, 2009.
  1. sharkman987
    sharkman987 New Member
    27
    Apr 22, 2009
    Is it ok to leave the bottle on while towing? I asked my dad and he didn't think so. Mine my clamping on with wing nuts like I'm sure all of them do.
    Thanks
  2. dupreet
    dupreet New Member
    2,184
    Jul 5, 2007
    High Point, North Carolina
    Yes, by all means, leave it on the trailer tongue. I have two bolts with wing nuts that secures mine....I add a bungee cord just to keep it from wiggling any.
    It is best to shut the valve off while traveling. This is a requirement in a lot of places.
    Happy Trails,
  3. jwolfe01
    jwolfe01 Honeoye, NY
    779
    May 5, 2008
    Honeoye Falls, NY
    I leave mine on the camper, but the valves should be completely closed. Im not sure if you meant on the camper or on as in the valves open.
  4. dcj070454
    dcj070454 New Member
    446
    May 14, 2009
    Canton, Ohio
    Sure full tanks are fine, if empty you are without when you get to the CG. There are times they can't be turned on, like when running the refer and refueling your TV, but heck ya, keep em full up.
  5. sharkman987
    27
    Apr 22, 2009
    Yep I meant attached to the pop up through wing nuts. I don't intend to leave the propane tank hooked up to anything just attached with the valve fully closed.
    Thanks a bunch :)
  6. barb_dave
    barb_dave Active Member
    1,731
    Jul 22, 2007
    Wisconsin
    Towing with full tanks id fine, I leave the gas line hooked up but the valve is never open when towing.
  7. Xolthrax
    Xolthrax Franconia, Pa.
    4,648
    Mar 17, 2007
    Franconia, Pa. Butter capital of the East
    Towing with them attached to the camper (but closed) is fine. If there are any tunnels on your rooute, you may wish to check with them to see what the limit is.
    If you are thinking of travelling with your tanks turned on, don't go through a tunnel or try to stop at a gas station!
  8. binky
    binky New Member
    484
    Aug 22, 2007
    Virginia
    While towing a trailer through tunnels in eastern Virginia, the propane must be turned off.
  9. turtle
    turtle New Member
    564
    Feb 14, 2007
    I do use mine to run the fridge but be sure to have enough gas as too not have to fuel while the fridge is on otherwise msut turn off fridge and restar when finished fueling. I know there are those who say this is a no, no and many who travel this way. I only leave fridge on propane if traveling more than a couple of hours.
  10. Djsrcy
    Djsrcy Member
    250
    Mar 9, 2009
    when i got my camper, they told me i could travel with the propane running the fridge which would mean the valves would be opened. Are they trying to kill me?
  11. dcj070454
    446
    May 14, 2009
    Canton, Ohio
    If you have to stop for fuel in your TV, the propane, and this is law has to be off. Best to tow off. Propane is heavier than air, remember when gasoline burns, it is not the gas liquid burning, it is the vapors.
  12. Unstable_Tripod
    14,279
    30
    May 20, 2008
    Seattle, Washington
    I always tow with the propane on and running my fridge. Absolutely no problems and it is completely legal in most states.
  13. CampingFamily1
    CampingFamily1 Active Member
    649
    104
    May 12, 2007
    Minneapolis/St. Paul, MN
    I was told the valves should be closed when in motion
  14. WV Hillbilly
    WV Hillbilly Terra Alta, West Virginia
    108
    Oct 1, 2008
    How many times have you been stop by the "law" to check to see if your propane is on or off? [}:)]
  15. jenoble99
    jenoble99 New Member
    379
    Jul 3, 2008
    Indiana
    I do it both ways, if I am off work and we are heading from home to the campground I will pre-cool and shut off for the drive. If I pull the camper from home to work and then to campground after work I will leave it on with the fridge lit to keep it during the work day. In this case I light the fridge before leaving for work and let it run on the trip there and throughout the day.
  16. Xolthrax
    4,648
    Mar 17, 2007
    Unless you're crossing a bridge, passing through a tunnel, or stopping at a gas station.
  17. TigerCamper
    TigerCamper New Member
    31
    May 20, 2009
    Georgia
    n00b question - I have never used the propane for the frig. Is it as simple as making sure the propane tank is open and turning the frig knob to 'gas'?
  18. Xolthrax
    4,648
    Mar 17, 2007
    That's the easy part. Then you have to ignite it [;{}]. I don't know about anyone else, but mine is stubborn to light. Once lit, you have to hold the valve open for about 30 seconds for the thermocouple to warm up. Then you're good to go.
    One caveat, I find that my fridge runs coldest when on propane. If temperatures are moderate, don't run it on high, or you may wind up freezing things (milksicles, anyone?).
