Is it possible to replace janky crank downs with scissor stablizers
Discussion in 'Stabilizing Your Camper' started by qswv, May 22, 2016.
  1. qswv
    qswv Member
    36
    May 30, 2010
    Greetings, I'm attempting to improve stability in our unfurled 2001 Coleman Taos. The original crank down stabilizers are still on there and they are fairly bent / janky. I'd like to replace them with scissor stabilizers if possible. Does anyone know if this is possible without welding? The current stabilizers are attached to the bottom of the PUP with two bolts. I've attempted to attach photos, hopefully they come through.
    Any advice on this topic would be very helpful. Perhaps my only option is to replace the current crank downs with newer crank downs, but I'd like to rule out scissors first as they are my first repair preference.
    Thanks for any help!
  2. kitphantom
    12,290
    1,291
    Another option would be stack jacks. Our first pup only had two stabilizers, of the style you now have, and one was broken by the time we owned it. 4 stack jacks were compact to carry, and make it very stable.
  3. qswv
    qswv Member
    36
    May 30, 2010
    Thanks for the idea KitPhantom, inexpensive and they get great reviews on etrailer. I'll check them out.
    Thanks again!
  4. friartuck
    friartuck Well-Known Member
    2,924
    131
    Nov 1, 2007
    Perry, MI
    I had the flip down stabs on my '04 Yuma and replaced them with BAL screw down stabs. Bolts only, no welding required. And I was able to unbolt the existing stabs, so no cutting either! [;)]
  5. richardm311
    richardm311 New Member
    32
    Oct 27, 2015
    I am looking into upgrading this same issue. I even bought 4 brand new coleman legs. 2 of the bent the first time we used them. Garbage. Friar, you say that the BAL screws bolt directly into the current holes used by the flip down jacks?
    Also, What are these stack jacks? How did you use them with only tow flip down jacks?
    Thanks for all the info.
  6. Snow
    10,813
    1,532
  7. Natureangel
    1,094
    294
    Feb 28, 2016
    Illinois
    Amazon has the same stack jacks for $30.
  8. Halford
    Halford Well-Known Member
    3,563
    568
    Sep 28, 2011
    Santa Clarita, California
    Yes, you can replace the old ones for new scissor jacks. It is just my opinion...
    But are you prepared to bend over to put stack jacks under the popup? You got storage room for these jacks?
  9. kitphantom
    12,290
    1,291
    Stack jacks aren't the answer for everything, but they weren't difficult to use on our first pup. I could crank up the screw almost as far as I needed it before putting it under the pup. On that pup, we had two places on the back, where the original jacks were, for one set. The front ones were placed wherever was handy on the A-frame, though we tried to keep them as close to the outer edges of the pup as possible. They usually traveled in the tote of site supplies, or on the floor in the TV.
