• The Forum will be unavailable on March 27, 2023 from 8:AM to 12:00 PM EST for maintenance.
Is it true that windows will crack in cold weather?
zinger60
331
Northern IN
I have heard some people say the windows will crack when putting camper up or down in cold weather and some say it isn't true. And if it is true, how cold is too cold?
kitphantom
Platinum Supporting Member
14,124
We've camped into the teens, though it was probably in the twenties as we put the pup up and down. No problems with the windows in either pup. The vinyl and tenting take a bit longer to settle, though, when closing it down. We did try to leave heat on as long a possible to keep things as pliable as they might be.
Hawkester
Hawkesnest
May 23, 2008
1,337
SE Wisconsin
"How low can you go"? [LOL]
We have also camped in the teens and had no issues, same as kitphantom we kept the heat on as long as we could and it took a little longer to close up because we took our time but all went well.
Dont know if I'd want to try it in single digits...
BigBaron
Dreaming of Tommy's chili cheeseburgers...
Jun 21, 2012
4,586
We regularly camp in temps well below freezing (5 degrees or less) and have had no problems.
Groogrux
Jul 10, 2015
17
I was just coming here to ask this exact question. I'd like to set up our camper in the driveway Thanksgiving weekend as we
will have a house full of guests and it would be nice to have a little retreat. We live outside of Philly so it could get into the 30s. We'd be able to pack it up during the day when it is a little warmer. Think we'd be ok?
bondebond
2,330
With a new PUP like yours, just keep the vinyl as warm as you can until you're ready to crank down. Mine is getting old enough and stiff enough that I would be concerned taking it down in temperatures that were below freezing. Technically, there's nothing magical about 32 degrees F or 0 degrees C as there's no water content in clear vinyl, but it does make for a good mental threshold. Vinyl will just get stiffer as temperatures drop, to the point it can crack if too cold. How cold is that? I don't know, hope to not find out first hand, and would recommend checking with the vinyl industry to find out.
BillyMc
2,489
I went searching for an answer to this question and found one. This is just before the Q and A section of the page.
TEMPERATURE
Each gauge of vinyl has a cold crack rating. This is determined with an impact test or by sharply folding the vinyl. The vinyl will become more brittle the colder it gets, but it doesn’t necessarily mean that it will crack. If you’re not handling it roughly, it may be fine in colder temperatures.
The cold crack temperature is 0° F for all gauges up to the 30 gauge. The 30 gauge rating is -29° F, 40 gauge is -30° F, and the 60 gauge is -10° F.
bobinfleet
1,362
Hampshire UK
I have not had a problem with high twenties when packing away.Many years ago in my youth I got on my motorbike at -13 and the vinyl seat cracked like glass, that was cold[:>(][:>(]
xxxapache
4,605
I had a Jeep CJ window crack when I tapped on it to knock the snow off. It probably wasn't below 20 degrees. I also had a vinyl car seat crack like an egg when I sat on it in about 20 degree weather...In both cases the material that cracked was 15-20 years old. I would guess age had something to do with it.
P
Punnster
Guest
I have a 1984 Shasta 165 pop up. I've 'nursed' it along these past years and it's held up fairly well. Going out in a couple of weekends to Door county, WI. Temp range predicted to be 55 day 45 nite. I'm concerned about the vinyl windows. From what I've read here, it sounds like a crap shoot. Question: Is there anything I can apply or a treatment for the windows that could improve my chances if success?
BikeNFish
4,568
Maplewood, MN
I don't know if there is anything you could apply because the cracking will be at the molecular level. Without getting too technical, plastics have unique molecular structure. Once those molecules cool and slow down enough, cracking in going to happen. Coating the windows with anything other that something that keeps the windows heated will not speed up the molecules to avoid rigidity.
Anything below zero Fahrenheit and you are taking a chance.
HERE is another thread on the subject.
FARfetched
743
Sector 706, Planet Georgia
I don't think you'll have an issue at 45°F, especially if you're using any kind of heat inside.
The grandson and I did a Camp Driveway in February, when the lows were around 34°F. I ran a Little Buddy heater along with a not-so-good electric space heater, and the interior temp was around 54°F both mornings (measured with a digital thermometer). That was a "bare" popup, no Popup Gizmos or Reflectix, and we left the rear bunk area open and unused. First thing I did each morning was to fire up the stove and heat up some water in a teakettle (and incidentally, the rest of the camper). The hot water went into a French press, which warmed me up a good bit more.
Closing up the camper presented no problems, and it might have been 55°F at that point. If the windows don't feel stiff when it's time to fold everything down, you should be fine.
mk4
Nov 20, 2014
99
It depends on the quality and age of your "glass". It's called isinglass. It has certain properties. I think most manufacturers will use Strataglass, but it's cheqp to replace. Most pups use like a 20 gauge. It should not crack unless uv damaged.
