Is Shower Cassette Toilet Removable?
Discussion in 'Camper Pre-Purchase Questions' started by Nani2, Jul 14, 2018.
  1. Nani2
    Nani2 Active Member
    292
    120
    Jul 9, 2018
    Tennessee
    We are looking at a 2018 Flagstaff 228 with the shower cassette toilet.
    I don't see us using it.
    It is bolted in. Could we easily remove it without damaging it in case we wanted it later?
    We are also trying to get the weight down. How much would we decrease by removing it and the rolling container and the 2 curtains?
  2. Fixitup
    Fixitup Active Member
    408
    240
    Jun 7, 2016
    Why dont you look at a unit that does not have a toilet. If weight is an issue look at a lighter unit.
    kitphantom and Sjm9911 like this.
  3. emoney
    emoney Well-Known Member
    880
    452
    Jul 7, 2018
    If it’s a towing issue I can’t imagine you would save enough weight to matter. Don’t forget, all your camping gear, clothes, food etc has to factor in as well
  4. Sjm9911
    6,574
    3,948
    Not saving much in weight. But I think it can be removed easily, and patch the floor. As for reinstalling, probubly harder.
    kitphantom likes this.
  5. mattlreese
    mattlreese Active Member
    231
    71
    Sep 6, 2017
    I bet it weights less the 100 lbs.
    I am sure it can be removed without any issue, but I agree with the others of you are that close on weight you are already overweight with gear.
    What's your tow capacity?
  6. Nani2
    Nani2 Active Member
    292
    120
    Jul 9, 2018
    Tennessee
    I like this one because it has a king and queen bed but it's at the upper end of our target weight. Trying to make it work for us.
    This model is hard to find. It is actually 200 miles away.
  7. Nani2
    Nani2 Active Member
    292
    120
    Jul 9, 2018
    Tennessee
    Our stated capacity is 3500 but I have heard Siennas are not good tow vehicles and we should stay low 2000 lbs. We are no where close on weight now but are watching and trying to stay low. But that king mattress is really appealing!!
    I also would prefer to have that cabinet for storage rather than a toilet in my kitchen.
  8. Orchid
    Orchid Sharp Shootin' Grandma
    5,672
    2,511
    May 8, 2011
    Florida by way of WV and MD
    I think it would be a mistake to remove it. You could still use the area for storage. I would be very surprised if it made any real difference in weight. They heaviest things are carrying water and propane tanks. I don't travel with either. Made my camper total electric since we always camp with hook-ups.
    Nani2 likes this.
  9. Nani2
    Nani2 Active Member
    292
    120
    Jul 9, 2018
    Tennessee
    We don't plan to carry water either. We will use a propane tank some trips and leave it home others.
    I thought the enclosure would be heavy like a porcelain bath tub.
  10. mattlreese
    231
    71
    Sep 6, 2017
    I also do not carry water to save weight.
    I tow with a pacifica minivan, dry weight 2500 lbs and I have not had an issue yet.
  11. Orchid
    5,672
    2,511
    May 8, 2011
    It's very light plastic. The heaviest part of it is the flip up wall. You could take the hinges off and remove that, but it would be nice to keep if you are using the area for storage. Honestly, I don't think the weight savings would be worth it.
  12. kitphantom
    12,219
    1,226
    RV bathroom and toilet construction is lightweight. (It's possible to buy a porcelain toilet, but I doubt they're standard except on the larger RVs.) Curtains wouldn't save enough weight to bother removing. Tote probably doesn't weigh much either.
    LP and battery on the tongue are weight, but they also often help keep tongue weight where it needs to be (10-15%) - lighten it too much and sway issues can develop.
    We didn't have water in either pup, we used 4-7 gallon jugs in the tow vehicle. We never travel without a jug or two of water in the TV, given where we camp/travel. (We do fill the fresh water tank on our TT, it tows better with the lower center of gravity and we can use it en route. The majority of our camping is in campgrounds without hookups, and often no handy place to fill the tank directly.)
    If you want to keep your total weight below 2000# you may need to keep looking for lighter weight campers. Something like one of the Livin Lite pups might be an idea. Remember that dry weight is a semi-useless number - you'll need clothing, etc. so it counts as cargo either in the tow vehicle or camper. Our Coleman Cobalt, which had a queen bed and was an 8' camper, was around 2500# loaded.
  13. BillyMc
    BillyMc Well-Known Member
    1,433
    756
    Mar 25, 2018
    Weight savings wouldn't be enough to be worth the hassle of removing it. If you're that tight on weight you might want to consider a lighter camper or a TV with a higher tow rating. BTW a toilet it the camper is your best feature when you need to make an emergency toilet run and it's dark and raining outside.
  14. Tumbleweed53
    Tumbleweed53 Member
    36
    17
    Sep 11, 2016
    Even if you don't use the toilet area, you can use if for light storage.
