Is the center seam supposed to be like this? 2000 Viking 2485ST
Discussion in 'Camper Pre-Purchase Questions' started by CamperChrissy, Mar 5, 2018.
  1. CamperChrissy
    CamperChrissy Well-Known Member
    656
    365
    Nov 25, 2016
    Chicago suburbs
    Looked at a Viking for sale today and noticed that the roof seam seems kind of bare. It is the 2 sheet metal halves of the roof that meet in the middle. Only thing covering that seam is some old, half-missing caulk/tape stuff. My Jayco has a metal channel that covers the seam, a vinyl strip that goes in the channel, and then caulk the sides of the channel. Seller said that's how it's supposed to be, from the factory. I did not see any screw holes along the seam, which would indicate a missing piece. Is this how it's supposed to be? upload_2018-3-5_15-12-19.png
  2. Orchid
    Orchid Sharp Shootin' Grandma
    5,819
    2,744
    May 8, 2011
    Florida by way of WV and MD
    I've never seen one, but that doesn't look right. They need to clean that out and get some Dicor in there asap, regardless.
  3. myride
    myride Well-Known Member Gold Supporting Member
    1,221
    672
    May 14, 2015
    Edmonton, AB
    I'm thinking there is deffinately something amiss here.....and by the loops of that call job I'd be worried about water penetration.
  4. austinm48
    austinm48 http://s1174.photobucket.com/albums/r604/austinm48
    298
    Dec 5, 2011
    mine is the same way never had a problem at all ... i did work at a sign shop and covered mine in vinyl just to be sure
  5. myride
    1,221
    672
    May 14, 2015
    Edmonton, AB
    If that' the case with Viking products glad I didn't buy one.....talk about a maintenance headache....
    jnc likes this.
  6. nineoaks2004
    8,244
    3,715
    Dukes, Fl
    Does not look very good. If it hasn't leaked, needs to me cleaned really well and I would re-seal with Dicor. If it has leaked that could /would be a problem. Good Luck and Happy Camping
  7. austinm48
    298
    Dec 5, 2011
    my only leak ever in that roof is the ac is not well supported and it vibrates loose... then leaks around the seal i figure it was made in two halves like a commeecial aluminum window frame and leaks into the seam so the metal groove inside can catch the water and channel it out, so if it gets sealed then the watwr will pool behind and cause a leak. mine has never had a leak on that seam so i leave it alone, i did reseal the edges, and i took the rubber covers off the edge of the roof and found they were cheap on screws so i put more in to tighten the roof and fill the holes they skipped
  8. CamperChrissy
    656
    365
    Nov 25, 2016
    Chicago suburbs
    Thanks for the input all. I have to say, I didn't see any obvious signs of water damage. However I noticed that the caulk all around seemed old and moldy and pulling away and the trunk lid seemed warped and the gasket was loose. So I decided to pass. Even thought I couldn't see any water damage, I just didn't have a good feeling about it for some reason.
    Orchid and jnc like this.
  9. myride
    1,221
    672
    May 14, 2015
    Edmonton, AB
    ALWAYS go with your gut instinct. ..
  10. austinm48
    298
    Dec 5, 2011
    i do not have the trunk on mine i did re caulk edges a few years ago mine i found out after i bought it had a lift post top pulled out of thewood which i had to make work
  11. tombiasi
    6,670
    2,233
    Looks like moisture gut under the caulk and finally it peeled off showing mildew underneath.
  12. peter moyes
    peter moyes Active Member
    136
    32
    Feb 6, 2018
    it is a 2 part roof seem yours is missing,,,its a raised seem check out colaeman roof pics
